| Cummins Conversions - Shop Talk - Tools - Fabrication Discussion Of Cummins Conversion Projects, Tools , Tool Boxes , Garages , Shops , Fabrication ect...NO ADVERTISING |
5600 conversion list
i need a list of parts to convert a 2002 old bs 4x4 cummins from a auto to a nv5600 manual. thanks for your help... mark
edge juice hot, tst j hook, stacks and silencer ring mia, stage 3 edge nozzles, 1/2" vulcon fuel line and draw straw 2, from the tank to the vp, plus a pro comp pump installed as my lift pump at a steady 20psi and 3" lift, 305/70/16's bfg's Last edited by 2002cumin : 09-02-2008 at 09:56 AM. |
#2 (permalink) |
should i just try and find a parts truck... thanks mark
edge juice hot, tst j hook, stacks and silencer ring mia, stage 3 edge nozzles, 1/2" vulcon fuel line and draw straw 2, from the tank to the vp, plus a pro comp pump installed as my lift pump at a steady 20psi and 3" lift, 305/70/16's bfg's |
#3 (permalink) |
diesel dynamix
i would. i just did a swap for a guy in a 12v truck and he spent almost $7k on all the parts. he got alot of it from Mopar and South Bend. take it he probibly didnt shop around but still.
2001 2500, airdog 150gph, TST pm3 competition, smarty, suncoast billet, banks air horn. AFE stage 2, 5" exhaust, 8" tip. head studs, turbo and injectors, tubes and lines ,hot rod pump coming soon.
#4 (permalink) |
Make youself a list of the needed parts for the swap.... then start shopping or like "jrmoparin91" suggests, find a doner. Also I do believe that a 2002 would have had the 47RE (electronic) so I'm wondering if you would have to figure how to terminate the electronics, so that you are not throwing the check engine light??? Hopefully someone knows if that's an issue and how it is solved.
#5 (permalink) |
As for a list..... here is what come to mind. NV5600 Adapter plate Bellhousing Fork & bearing Flywheel 13" Clutch 13" w 1-3/8 input Hydraulics - master/slave Transfer case - 29 spline input Brake/clutch peddle assembly Manual steering column Shift boot Anything else?
