High PSI Wastegates?? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 07-12-2006, 03:24 PM Thread Starter
Where does one buy an external adjustable wastegate that is adjustable from say 30 psi up to 70-80 psi
Cant seem to find anything over about 15 psi
Can I just buy one of those and put a bigger spring in it? Or is the housing too weak as well?
Thoughts?
Thanx
Ken
96 Fummins, north of 7, n havin fun
seeker1056 is offline
post #2 of 8 (permalink) Old 07-12-2006, 03:44 PM
Jeff K's Avatar
depending on what you want to do, a 15psi wastegate will be fine for your application. What you need to do is run one line from the manifold to the bottom side of the wastegate actuator and run another line from the manifold through pressure regulator to the top side. Then if you have a 15psi spring you set the pressure regulator to 15psi lower than the pressure you want to start the wastegate opening. Basically you will have equal pressure on the top and bottom of the wastegate actuator until the pressure regulator starts limiting the pressure to the top side.
Here is a diagram of what I am talking about....
http://www.tialsport.com/documents/w..._wginstall.pdf
2012 Mega with HRT Offroad built Carli 6" Performance 2.5 system
Jeff K is offline
post #3 of 8 (permalink) Old 07-13-2006, 08:41 AM Thread Starter
Awesome idea!!!!!
thanx much
Does one use a regular wastegate and drill n tap for the second port, or are there two port wastegates out there for a reasonable price
Thanx again
Ken
post #4 of 8 (permalink) Old 07-26-2006, 09:43 PM
Jeff K's Avatar
Almost, if not all external wastegates will have two ports
Jeff K is offline
post #5 of 8 (permalink) Old 08-08-2006, 07:18 PM
Trapper's Avatar
What would you use to regulate the pressure of the secondary trubo? Say you only wantted to see 50psi?
Trapper is offline
post #6 of 8 (permalink) Old 09-02-2008, 11:48 PM
cummins002500's Avatar
a wastegate between your top turbo down pipe to the flange of your bottom turbo with a boost controller
cummins002500 is offline
post #7 of 8 (permalink) Old 02-17-2009, 02:45 PM
rattledbycummins's Avatar
allright i gotta question for you in the thread. you guys seem to have the external wastegate thing down pat. so on my 99 cummins i have a hx 40 tubo with the wastegate plugged off. so if i got a typical wastegate say for a ricer how would i go about hooking it up on my truck? i can fabricate whatever i have to make it work. thanks guys
1999 Dodge Ram 2500HD CUMMINS P-Pump 24V
Bunch Of Goodies
2004 2500 CCSB 6SPD
rattledbycummins is offline
post #8 of 8 (permalink) Old 04-14-2011, 10:05 PM
Boost?
hey guys i have a 97 12v... i have a 5 inch straight pipe to 5 inch stack with the stock wastegate i boosted about 26 psi...i use to have a 6 inch stack i boosted 28 30 psi.... but now with the 5 inch stack and a banks waste gate im boosting 21psi? it doesnt feel slower its just frustrating me... my buddy told me he boosted 35 psi with that same banks wastegate? i tried adjusting it and still 21 psi? any suggestions...or suggest any other mod to make me boost more
12vpowerhouse1 is offline
