Putting a 12v in a 2011 Silverado - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Cummins Conversions - Shop Talk - Tools - Fabrication
Old 04-16-2012, 07:37 PM   #1 (permalink)
LiftedDually97's Avatar
Wanting to see what everyone thought about this. Been wanting to swap a diesel in my 2011 Silverado 1500, and figuring the 12v would probably be the easiest to swap in. Power goals are around 550hp and 800+ tq. What tranny would yall reccomend? 47re? Nv5600? Allison?
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Looking for a 2010+ 2500 Crew
Show Truck: 2011 Silverado, 15" FTS Lift w/ Coilovers & Ressi's, 5.38s, 38 Mud Grapplers on 20x12 Hostages
LiftedDually97 is offline   Reply With Quote
Old 04-16-2012, 10:35 PM   #2 (permalink)
No one has any suggestions?
I'm figuring on a custom 50gal fuel cell mounted at the front of the bed under it and either running a mechanical fuel pump setup, or going a custom electric setup.
Motor mounts I know are going to have to be fabbed, as I'm sure no company has attempted/done this yet.
Still no ideas though for a good tranny that is strong? I'm leaning towards the nv5600 for the 6spd option, the ease of install, and the fact that I can upgrade to a SB clutch and have no worries.
My main concerns are wiring this demon up and still using the factory cluster.
Old 04-17-2012, 10:56 PM   #3 (permalink)
first off, is this a 2wd, or 4wd in case i missed it
secondly, its a rack and pinion steering setup on half tons. i myself have a 2011, 5.3, 6spd "mini allison", 3.42s, extended cab shortbed
a good sized cummins weighs in around 12-1300 pounds. the frame might be ok, but the whole front end will be screamin'. so you would have too look into at least finding beefy front end components to hold the extra weight. next option would be to go solid axle. i believe theres only one guy that has done a conversion on the NNBS chevys. he used a steering box off of a 82-92 trans-am, camaro, etc if i remember right. he only posted a pic or 2 and didnt have much more info about it. so if you delete the rack and pinion and go solid, your looking, say, at LEAST 5K to do it right. axle, rebuild parts, springs, shackles, the parts list will be tremendous... so after you delete all that and go solid, there goes the factory stabili-trak.
the rear-end won't hold up long either. GM messed up here and stuck drum brakes on the half tons. so then you godda swap out the rear. big diesel torque will grenade that diff like it was made of paper. so then its a rear axle swap, and another 4K estimate.
what about all the electronics? if said truck is a WT trim level, it shouldnt be too bad. however, if its an LT with OnStar, remote start, etc, its going to be a MAJOR PITA to make everything work. fly-by-wire, cruise... ur talkin huge headaches, alot of money, and more than likely poor results. also, you might even have to yank out the cooling system. the cooling fan is electrically driven, computer controlled im sure. ^back up to the last paragraph about electronics, the ABS would be gone, and god knows the existing brake components are all electronic.
sure you could just yank out the chevy computers, gauges, wires and everything, but thats going to be more work. if the truck is in decent condition you could part all that stuff out for a premium price and get some money back tho. im sure you could find somebody out there looking for a motor and trans combo for an 11'. especially if its a 5.3 and 6spd combo. IIRC the trans could either be a 6L80E or 6L90E. id give "circle d transmission" down in texas. those guys pump these up all the time and could prolly use it for a core charge. i think these are the same transmissions put behind 6.0s, and 6.2 camaro/corvette. circle d apparently builds them to hold 600hp consistantly with no complaints. but mind you! these are gasser applications and wouldnt hold up behind big diesel torque.
so sell off the current drivetrain to help pay for the custom fab motor mounts and other parts. might get 8k if it has real low miles. oh yea, forgot. the transfer case would have to be swapped too. thats electronic
excuse the long rant, but its just not very cost affective AT ALL. you would be better off trying to find an early GMT900 truck for cheap. as in a crap-ton of miles, broken drivetrain, etc, and just using the body and frame. right now, nobody has done this because its not cheap, and by no means easy. in a 2500 or 3500? yea sure i could see it happening. much more suitable for a swap
i believe nobody posted comments because this "swap" is near impossible for the average garage tinker-guy
84 CUCV is offline   Reply With Quote
Old 04-17-2012, 11:01 PM   #4 (permalink)
Diesel Junkie
Taquache's Avatar
iTrader Score: 6 reviews
alot of good poins mentioned ^^
What are your goals for the truck and why do you want to do this swap? on average the estimated cummins conversion is roughly $10,000 to do it properly
Click HERE To Find Out How To Help Bring <-- THIS 8 sec Diesel Drag Truck from THAILAND to the NHRDA World Finals in Ennis, TX September 28th
Taquache is offline   Reply With Quote
Old 04-18-2012, 11:15 AM   #5 (permalink)
Tech Specialist
I've been thinking of doing the same with an F150.
As long as the front end is capable of supporting a snow plow it should stand up to the weight of a Cummins. Snow plows are lighter, but they stick out further in front of the axle.
I'd be more worried about the length of the engine compartment, from firewall to radiator.
The electronics takes some effort, but its do able.
"It's good for up to 550hp however we do not recommend you tow at that level with the 68rfe"
Superduty is offline   Reply With Quote
Old 04-18-2012, 02:06 PM   #6 (permalink)
12V ADDICT!
Nater Tater's Avatar
The torque would prolly twist the frame like a pretzel. But it all comes down to cash. If you got it to do this and the time and know how...yea its all possible
[COLOR="black"] "PROJECT DIVORCE"1996 Dodge 2500 eclb, NV4500, SouthBend clutch,5" straight tb to 5" Silverline aussie stacks,no fuel plate,afc mods,silencer ring mia, BHAF, 3k GSK, Used Ranch Hand bumpers,KDP fixed and lots to come.177k on the clock
Sold....2010 Dodge 3500 SRW, G56, With deletes and lots of extras....to a fellow Cumminsforum member!
For sale- 91 12v runs like a top. Engine only
Dads:1991rc W250 red and fully restored. 600k miles with manual trans
Nater Tater is offline   Reply With Quote
The Following User Says Thank You to Nater Tater For This Useful Post:
Alabama Mud Machine (04-18-2012)
