02superduty 12valve swap - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Cummins Conversions - Shop Talk - Tools - Fabrication
Old 12-19-2011, 06:51 PM   #1 (permalink)
it was 5.4 gas motor would the 6 speed from behind 7.3 be strong enough
prettypenny is offline   Reply With Quote
Old 12-20-2011, 07:32 AM   #2 (permalink)
badmfron's Avatar
Absolutely!...zf6's are very stout.
92-12valve, maxed ve, 3200 gsk, tight afc, 5x14 sac Lee Jessie injectors, custom Steed Speed (vgt) manifold, mechanically controlled he351ve, 6.0 intercooler w/ 3" pipes, 5" turbo back single stack, Glowshift 3-in-1, Fluidampr, SBC con-ofe, short throw shifter, homemade adapter plate, ZF6-s750/NP271, 4.88's on 37" Mud Grapplers, elevated 12" in a 04 super duty________B.O.T.T.S.R.
James Oyer
01/05/1978 - 05/28/2012
Thank You for being my "TRUE FRIEND" We love you Jim.
badmfron is offline   Reply With Quote
Old 12-20-2011, 07:55 AM   #3 (permalink)
Meyers Farms's Avatar
Heck ya I'm loving mine! Got a 6 speed nv5600 dual disk clutch in front of mine and its working great
2001 Fummins 12V ZF6 ECLB 4x4
Meyers Farms is offline   Reply With Quote
Old 12-20-2011, 07:58 AM   #4 (permalink)
Make sure you check the trans tunnel in the truck bc a 6 spd trans tunnel is taller than the auto tunnel in the superduty. They are not bolt in. You have to cut and weld
Old 12-20-2011, 01:59 PM   #5 (permalink)
ok great info so the nv5600 clutch will work
Old 12-20-2011, 02:01 PM   #6 (permalink)
my plan is to get radiator intercooler trans transfer case from 02 7.3 is thAT GOOD OR ARE THE 6.0 INTERCOOLER AND RADIATORS better? id like to only do it once so any help or advice is great
Old 12-21-2011, 03:25 AM   #7 (permalink)
badmfron's Avatar
Radiator don't matter...I run the 5.4 rad that came in mine. I have no cooling issues at all, and I play hard in this truck down south in florida.
Intercooler is up to you... I would use witch ever you have access to.
7.3 is a stronger design with aluminum ends. 6.0 will cool a lil more but uses plastic ends. It is rumored that the 6.0 intercooler ends can blow off. But it's a non-issue unless your running 100psi+ of boost.
With that said...your plan sounds good to me.
James Oyer
Old 12-21-2011, 02:51 PM   #8 (permalink)
ok thanks i wasnt sure on radiator
Old 12-24-2011, 11:27 AM   #9 (permalink)
Yep I'm using a Dual disk Valair NV5600 clutch with a NV5600 13" flywheel and no starter spacer with a FordCummins adapter plate.
Just call Valair and they will put a Ford pilot bearing in the flywheel and include a Ford alignment tool at no extra charge.
Old 12-24-2011, 11:25 PM   #10 (permalink)
ok i was gonna order kit from fordcummins with the adaptor plate , motor mounts and exhaust manifold
Old 12-25-2011, 12:11 AM   #11 (permalink)
machineboy93's Avatar
Yes fordcummins is the way to go! pretty simple and easy to follow! im finishing my conversion right now! everything is working like they say it will!
1993 F250 Cummins Conversion, Hx 35 non-wastegated 16 square cm. turbo housing, 40 hp injectors, Denny T Stage II Fuel Pin, Pump turned up a bit, ASA Cold Air Intake, 4 inch MBRP with Aero Turbine 4040 Non-Resonated, kdp killed,
machineboy93 is offline   Reply With Quote
Old 12-25-2011, 04:43 PM   #12 (permalink)
good to hear
