V10 to 12v conversion - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 10-12-2011, 11:18 AM Thread Starter
cumminsbeliever's Avatar
I have two 1995 trucks. The first is a 2wd auto that has a 12v in it. The second is a 4x4 with a V10 in it. I want to put my 12v from the 2wd into the 4x4 truck.
Is it as simple as haul the V10 out and drop the 12v in its place? Since both are auto, I don't see any issues there. I intend to keep the torque converter from the 12v and can swap the valvebodies if necessary.
What about wiring and gauges? And the grid heater, what controls that?
Is there a sort of computer somewhere that needs to be swapped, or just the wiring?
Does the V10 tranny bolt to the 12v engine?
Any and all help is much appreciated as I intend to do the swap this weekend. I have no interest in the V10 so please dont tell me to keep it and run that, after all this is the CF, the best forum anywhere. And yes I did do a search already. Thanks in advance for all your help.
2001 Ram 3500,6 speed dually,edge juice with attitude cts/4 inch exhaust,cool air intake, rv 275 injectors.
cumminsbeliever is offline
post #2 of 9 (permalink) Old 10-12-2011, 10:47 PM
Master of Mayhem NASFIG
rpage's Avatar
i would say take the wire harness and pcm from the 2x4 along with the radiator and intercooler. Not sure about what tranny the v10 has tho. The gauges should be fine except the tach maybe.
Really don't give a rat's App**
rpage is offline
post #3 of 9 (permalink) Old 10-14-2011, 09:38 PM Thread Starter
where is the PCM located? I picked up the 4x4 V10 today and have the front bumper, fenders, rad and intercooler off my diesel truck and am ready to pull the cummins out. I will remove the engine tomorrow and then start on removing the V10 from the other truck. So far so good. I intend to replace the instrument cluster to be able to have the wait to start light etc for the diesel. Do you know if this will just plug into the other dash? And you made reference to the wiring harness, do you mean the entire underhood harness? or is there a seperate one just for the tranny? Please everyone chime in with experiences or suggestions.
post #4 of 9 (permalink) Old 10-14-2011, 09:41 PM
rpage's Avatar
under the hood along with the tranny one and i think the pcm is behind the glove box. Been a long timne since i had a 95. it should just plug in.
rpage is offline
post #5 of 9 (permalink) Old 10-15-2011, 01:02 PM Thread Starter
If the PCM is behind the glove box, does that mean I have to seperste the wiring harness at the firewall? If I unplug the pcm and wiring harness from one truck and put it in the other, will all the interior controls still work like the lights, wipers etc
post #6 of 9 (permalink) Old 10-16-2011, 11:00 PM
rpage's Avatar
if you take all the wireing harness from the one to the other they should work since all the basics are the same.
rpage is offline
post #7 of 9 (permalink) Old 10-17-2011, 06:48 PM Thread Starter
I am 10 hours into the conversion and I have the Cummins out of the 2wd and have the front of the 4x4 off and all hoses and wiring disconected. So far it seems to be straight forward. I swaped pcm's over and have the wiring harness with the Cummins motor. I still have to pull the exhaust from the 2wd for the Cummins motor, and the dash cluster swap.
I will begin to unbolt the tranny from the 4x4 V10 and unhook all under truck exhaust etc to get ready to remove the v10. I did not remove the fenders from the V10 truck, but might later if it proves worthwile to get the V10 out and the Cummins in. My 12 year old played sick today so he could stay home from school to help with the truck. Just having the extra pair of hand to help pass tools and the odd help with things like hood removal proved to be a HUGE help. Back to school for him tomorrow and back to work for me. Not sure how much I will accomplish during the week as I leave at 5 am and return home at 8 pm. Long days and dont feel like crawling under a truck after a 2hour commute home. I will give updates as I go and will upload some pics soon. thanks for all the info from those who posted.
post #8 of 9 (permalink) Old 12-17-2011, 04:21 PM
how did it come out
hi
i would like to know how your conversion went im thinking of doing the same and have been told that the v10 swap was the easyist
thanks
thumper59 is offline
post #9 of 9 (permalink) Old 12-17-2011, 05:04 PM Thread Starter
Sorry that I did not finish this post. I have been very busy since the conversion.
If you have 2 truck, the concersion is straight forward. If you don't, be prepared to do a little searching for a few parts.
As far as the engine went, It was a direct fit as both trucks were auto tranny. If you are going from auto to standard, there will be some spacing issues.
I simply unplugged the 3 plugs from the wiring harness under the brake booster and unplugged all the tranny sensors and one from the transfer case and removed the engine all together with the wires. Then I just plugged them into the other truck and all was plug and play accept the plug on the transfer case, but same wires, so I snipped the plug off then got a new one from dodge and soldered it in and all was well.
The rad shroud is different on the diesel as the rad overflow bottle hooks to it, but it can be mounted on the inner fender if need be or get one from a gasser and it will bolt right to the inner fender.
All went relatively easy. I would recoment it to anyone willing to tackle this job, as it is much cheaper to find a v10 that is 4x4 and put in a cummins than it is to buy a 4x4 with a cummins in it.
There are a few more posts of mine on here about the swap, check them out and I think it will answer most of the questions you have, if not, feel free to ask, I will help as much as I can and will give you my phone number if you prefer to chat over the phone instead of typing. SEns me a PM and I will give the number if you like. The job would take about a full weekend of long days to get you all done. It took me longer, but I was unable to get a few hoses and had issues with brakes and brake lines on the other truck. Good luck, all the best.
