6bt swap in 97 Dakota...?s - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-02-2011, 09:48 AM Thread Starter
The#1Dakota's Avatar
Hi all!
I have always wanted to swap in a 12v p pump 94-98.5 in my 97 Dakota with NV4500 5spd. What the plans are for now... I have all the legal issues worked out with DMV, still have to get it inspected once installed tho. Have been researching this for a couple of years slowly.lol... Im am open to all recommendations, scrutiny ect. I want to build it right the 1st time. I know allot of people put the 4bt in the Dakotas but if Im doing this much work Im going big lol. Ive only seen 1 Dakota with a 6bt so far, so anymore info would be greatly appreciated.
Parts: Im still searching for an 12v, tranny&tcase. I have D60s front & rear from 85 f350 already, planning on leafs.
My 1st ?: in a tight fit for the engine would I benefit from a bent down manifold instead of the straight (normal) one? Gunna want to run twins one small one larger in future.
Thanks for the help!
2007 3500 5.9, SRW, Quad, SB, G56, 4x4, 6" lift
97 Dakota 5.2 5spd 4x4, 2"lift, auto meter, ham radio, cb Cummins swap soon......
The#1Dakota is offline
post #2 of 6 (permalink) Old 06-03-2011, 09:36 AM
JakeDiesel's Avatar
i think that ur gona want a tougher rear than than a dana 60. I think that i would go with a dana 80, especially if u plan on twins in the future.
If you plan on twins i would mount as many things as u can in the frame rail like batteries so you will have enough room under the hood. U r only going to have have about a 1" of room for the engine to move back in forth, u will have to use electric fans.
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude. 01 f650 with 5.9 cummins. 06 2500 all stock for now
JakeDiesel is offline
post #3 of 6 (permalink) Old 06-04-2011, 03:25 PM
Rear end, front end, middle "end" anmd the whole truck!! Save your money because that's all it's going to cost you - MONEY!
You're taking a weak-framed middi-sized pickup, built for a v-6 and trying to put a 415 ft. lb/ torque diesel in it!
Will it work? Sure it will.........and so would putting a 16 liter cat in a F-250, BUT for how long? 5 minutes/ 10 minutes? Till you hammered the throttle the 1st time, MAYBE!!!
Save your energy for something that will last more than a day and will have some value when you're done with it.
Rodbuilder is offline
post #4 of 6 (permalink) Old 06-05-2011, 02:35 AM Thread Starter
Ok thx for info. I would assume I will have to do a body lift also? I wonder if this would keep from modifying the transmission tunnel to minimum. From what Ive seen everyone is getting a custom radiator made and running 4 electric fans pushing from outside of engine bay.
Yeah, I was planning on bracing up the frame all the way through. Which is allot of work I see what u are saying, I just wanted something different seems like everyone has a full size diesel truck now. Really the 4bt would be a better choice with weight and power for a midsize I guess. Would be a little less custom work with radiator ect.
post #5 of 6 (permalink) Old 11-14-2011, 12:19 AM
here is my 6bt dakota. and i beat the piss out of it
http://http://www.pirate4x4.com/foru...d.php?t=966532
dobbers84 is offline
post #6 of 6 (permalink) Old 11-14-2011, 12:22 AM
