03 Ford v10 to 12v wiring questions. HELP!!! - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 03-14-2011, 07:52 PM Thread Starter
Ok guys here's the deal. I've researched and researched with no luck and I just got off the phone with Scott from destroked and this is what he gave me as far as wiring their tach kit.
pin 30 crankshaft sensor dark blue +
pin 31 camshaft sensor Red +
pin 41 crankshaft grey -
pin43 camshaft orange -
Problem is pin 30 and 31 are not punched out 41 is pink/white and there is no 43
the camshaft sensor wiring i have is dark green and a light blue
Also this truck only has a cylinder head temp (cht) sensor so what do I do for coolant temp?
The truck was an 2003 F250 lariat FX4 4R100 auto now 95 12v nv4500
Thanks in advance
ryland1503 is offline
post #2 of 10 (permalink) Old 03-16-2011, 03:22 PM
Ford62B's Avatar
What connector is he telling you to look at?
2004 Ford F350 Superduty DRW 5.9L 24V He351 VGT w/Fleece Box. 125+HP Injectors. EDGE Juice w/ATT.
Ford62B is offline
post #3 of 10 (permalink) Old 03-16-2011, 09:31 PM Thread Starter
He didn't say which connector, but I would assume it's main engine harness connector with the pin #s on the back.
post #4 of 10 (permalink) Old 05-21-2011, 02:39 PM
what did you find on this? Did you get it wired correctly?
billyrb is offline
post #5 of 10 (permalink) Old 05-24-2011, 02:57 PM Thread Starter
I had to wire crank + to one side of the tach sensor and tie the crank- and cam + together.
post #6 of 10 (permalink) Old 06-26-2011, 05:02 PM
ruben774's Avatar
Im having problems also!
So you hooked the dark blue to one of the pickup wires and tied the gray and dark green together? What did you do with the other pickup wire and the other cam sensor wire?
Also so how many teeth do you have on your tone wheel?
2003 2500 qc 4x4
2000 F250 4dr 4x4 fummins 12v G56 dd, #8 fuel plate
1995 2500 cc sb 4x4, p&p head, sdx5x12, 64/74,over s475, head studs, o-ringed, 22*
ruben774 is offline
post #7 of 10 (permalink) Old 06-27-2011, 02:26 PM Thread Starter
The tone wheel has 40 teeth and the cam - wire was not used.
post #8 of 10 (permalink) Old 06-27-2011, 04:36 PM
ruben774's Avatar
So are you hooking one wire to the dark blue and the other wire to the gray and dark green? And my tone wheel is a 12 pulse.
2003 2500 qc 4x4
ruben774 is offline
post #9 of 10 (permalink) Old 06-27-2011, 05:47 PM Thread Starter
Yes the cam + was Dark green and that is connected to crank- grey.
It depends on what your truck was before the swap i.e. diesel, v10, or 5.4 v8.
Most of the time you tie your crank+ and cam+ together and ground the other tach sensor wire. When I wired mine like I just stated my rpm would fall off at 2k go to 0 and after I let off the throttle it would go back to idle rpm.
post #10 of 10 (permalink) Old 06-28-2011, 02:40 PM
ruben774's Avatar
Mine's a v10
2003 2500 qc 4x4
ruben774 is offline
