Odbii Scanner - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Cummins Conversions - Shop Talk - Tools - Fabrication
Old 11-28-2005, 02:00 PM   #1 (permalink)
Guest
Guest
Posts: n/a
Cool Odbii Scanner
Well guys I just bought this one here ,,,, so if you all odbii locals have any CEL's on...... stop by and we'll take care of it for ya'
out the door for Grand Total: $113.94
Here
www.tradervar.com
Features
* Retrieves and clears all generic OBD II diagnostic codes.
* Compatible with all 1996 and newer OBD II compliant vehicles: North American, Asian & European.
* Supports HBCC, DLCP and ISO communications systems.
* Codes are shown on a 4-digit LED display.
* Code definitions are listed in the instruction manual.
* Separate function keys for Read Codes, Erase Codes and Scroll Codes.
* Attached J1962 diagnostic cable provides both data and power connections.
* Read and erase (reset) DTC'S
* Read pending codes I/Mmonitors MIL Status
* Trouble code definitions displayed on screen
* Menu driven large LCD display
* Field upgradeable
* Free CD Included
* !!! USER SUPPORT !!!
* Comprehensive owner's manual
* Toll-Free Technical Hotline and E-mail with ASE Certified Technicians
* Yearly firmware updates via user-replaceable chip.
* 1 year warranty.
* Made in U.S.A
Now I dont fear the CEL !!!!! WWWWwwwwoooahhahhahhaaa !!
Ok well maybe a little
DM
Old 11-28-2005, 02:26 PM   #2 (permalink)
Guest
Guest
Posts: n/a
Great buy DM, We have the Power pup box from Bullydog on the 04.5 and it has a code clear deal on it , never tried it yet but will check it out some day
Old 11-28-2005, 08:28 PM   #3 (permalink)
Tech Specialist
Gary - K7GLD's Avatar
AS I asked over on TDR, what does that gizmo do, other than ability to actually remove fault codes, that the dash error code readout doesn't already do?
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline   Reply With Quote
Old 11-28-2005, 08:47 PM   #4 (permalink)
Guest
Guest
Posts: n/a
Gary, the OBDII will plug into the data port under the steering column and retrieve all codes stored in the Puter, then it will also erase the troubled code so you can be on yer way............far as I know........ya know? Not all codes are retrievable by the 3 key method
Old 11-28-2005, 08:54 PM   #5 (permalink)
Tech Specialist
HMMmm - I like "toys", especially electronic ones, as much as the next guy, but not sure I'd get much meaningful use outta that one...
Old 11-28-2005, 10:02 PM   #6 (permalink)
DieselTweaker's Avatar
It's amazing what you can do with a high quality tool,,,,, what you can see and do on the inside. Most of your cheap scan tools just turn the light off, and give you the code. Knowing the code is the easy part,,, knowing what to check and diag. the code is the hard part,,,, which I think is the fun part.
It's also very funny the amount of stuff people will lie about when trying to geto something taken care of. There is info call freeze frame data, which is recorded and storted when certain code's are caused,,, I.E. engine load, RPM, VS, fuel trims, run time, engine coolant temp, intake air temp, timing, and many more.
oh,, and btw you have to watch and make sure the tool will work, newer car's are starting to use a CAN system (central area network) run's much faster. and you have to have one that will read can. just something to keep in mind for those of you who want to more.
NO BOX NO BOTTLE, JUST BALLS AND THROTTLE!
HIT LIST:
1:
2:
3:
DieselTweaker is offline   Reply With Quote
Old 11-28-2005, 11:15 PM   #7 (permalink)
Tech Specialist
IF your main interest is knowing what the codes are - what they mean, here, knock yerselfs out!
http://www.turbodieselregister.com/f...ighlight=codes
OH - and you can send the $100 you saved to ME!
Old 11-29-2005, 12:19 AM   #8 (permalink)
Keyser Söze
Code readers are entertaining, but if they don't give much more data than what the codes are, I personally find them useless. Sorry if that sounds harsh, but there are many ways to set the same code, and without a tool to run the system diag, show the parameter ID's, watch the sensors & what they're seeing & telling, all the code does is tell you where to start the pinpoint test at.
Some are more obvious than others, but some codes take some work to figure out.
But that's the mechanic in me talking.......
Mes chers frères, n'oubliez jamais, quand vous entendrez vanter le progrès des lumières, que la plus belle des ruses du diable est de vous persuader qu'il n'existe pas!
And like that, he's gone...
Radio Flyer is offline   Reply With Quote
Old 11-29-2005, 11:19 AM   #9 (permalink)
Tech Specialist
That's pretty much the way I see it too - maybe I'm just ignorant of the deeper and more detailed info they can provide.
But if I get a CES light, and then do the dash check for codes - and get the SAME indications the OBD gadget provides, what have I gained?
For instance, if a OBD or dash error codes simply states there is an error with low voltage to/from the MAF sensor, is the problem IN that sensor - or the device before or after it - or somewhere else entirely?
That OBD thing had BETTER either give more DETAILED info, or provide well-proven CURES for what the codes indicate, otherwise, the user is still left with a long trail of guesswork, trial and error.
Old 11-29-2005, 12:27 PM   #10 (permalink)
Guest
Guest
Posts: n/a
My CEL seems to have the potential opf poping up ,,, because of stupid things I may do ...LOL ... when it does i have to sit there and look at the CEL and wonder whats going on or what happened till I see an auto zone to get it cleared ,,,, and most of the time they do it so fast that I cant even see what the codes were.... heck one place charged me $40 to clear my codes and all the dealers want atleast $35 to do it ,,,,
This way Im my own warentee station I see my CEL pop up I whip the Scanner on see what screwed up ,,,clear it and there ya go '
I know for a fact that csevers carrys one with him in his truck to clear codes set by his stacked boxes
Yeah I could of got the real cool ~$500 snap on fancy one ... but I really just wanted my own scanner and the abillity of not haveing to relay on anyone else
DM
BTW advanced auto has the same scanner on sale for $99 right this second
Remember all I can get in the 2002 is the stupid companion code thats it with out a scanner you dont know what happened or why
So theres my reasoning in wanting one
Old 11-29-2005, 02:16 PM   #11 (permalink)
Keyser Söze
Chad, with my '99 I can't even get codes on the dash display, so I hear where you're coming from.
I like to wrench on my own stuff, wrench on other people's stuff, etc and having a real diagnostic scan tool, IMHO is better for my needs.
I still would've bought the billet fuel door. j/k
Old 11-29-2005, 03:19 PM   #12 (permalink)
Tech Specialist
Well Chad, I'm mildly interested in one, just because I love electronic gadgets - let us know what you think of yours in areas other than simply clearing codes - is the code reference section any more detailed and helpful than what I pointed to further up above, or are the error messages sorta cryptic, and still leave you scratching your head wondering what the problem really is?
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
