If its a p-pump, the solenoid has 3 wires. ground, hold and pull coils. cant recall off the top of my head the color coding, but you want ONLY the hold coil to have constant keyed power. The pull coil can only be energized momentairily (usually energized with the starter) as it draws high current and produces alot of heat.
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
The Following 2 Users Say Thank You to ykdave For This Useful Post:
The motor is a p-pump engine. The wire colors are black-white-red. Should the constant power be run through a relay? Any quess which wire is pull and which is open?
The big black one is ground. The little one in the middle is hold, and the one left over is pull. If you don't wire it through a relay, put an inline fuse in one of them just incase the starter contacts stick. You don't want to catch your truck on fire!
93 Chevy with '97 215 47rh 241DHD HE351cw/bht3b(26cm) Con7x12tagious
the hold coil could be put on a relay for safety (since what the engine is in is obviously doesnt have an ignition switch designed with this in mind!)
The pull coil definitely requires a relay. A regular 30/40amp relay 'might' work, but you should use the larger 70/80amp relays like what is used on the dodges
Fusable links for both coils is a great way to keep from starting unintended fires...
I'm having trouble whit my fuel pump runnig after the key is truned off; and it still runs after I pull fuse relay out of the fuse box under the hood. I have no idea in H**L where the short is, I NEED HELP ! Anyboby out there know something ?. rcfmnc/big red baby
Reason: a to add more details
I got a wire harnes that is made for conversions for the fuel seloniod. It was like 30 bucks comes with instructions, and relay. It is complete just plug in and put the wires where it says. Just go to eBay and search fuel soleniods.
My shutoff solenoid went out on my 12v and instead of letting dodge rape me i went to tractor supply and got a throttle cable for a tiller or tractor and ran it thru firewall and attached to fuel shut off arm. Now it is a real mechanical shutoff and i could take keys with me and leave it running and locked all day long.
Sent from my Autoguide iPad app
06 Airdog2,II85%cp3,Bosch100hpinjectors.coldair,banks hi ram intake,heater delete,bulldog crazylarry,ts mp8, dr. Performance rail plug,full billit tranny
