ford cummins - Dodge Cummins Diesel Forum
post #1 of 32 (permalink) Old 03-01-2010, 04:15 PM Thread Starter
ford cummins
I will be starting my Cummins swap hopefully next month. Its a 97 Ford f250hd with a 5.8. Swapping in a 89 Cummins. The only thing i did not realize when I started planning for this swap was how the fuel tanks switched. On all the older Ford trucks I had there was a selector valve on the frame. On this truck there is not. I guess it switches tanks with the in tank fuel pumps. My question is can I run the Cummins with the electric in tank pumps instead of the mechanical pump? Will the gas pumps work with diesel fuel? Thanks
Dillon is offline
post #2 of 32 (permalink) Old 03-01-2010, 04:57 PM
I am interested in this also. Anyone?
amcgibbon is offline
post #3 of 32 (permalink) Old 03-02-2010, 03:06 AM
Mr. Bob's Avatar
I found a truck being parted out... A 1995 PSD, Got tanks, pick ups, lines, selector valve and full harness for $100... Should be a direct bolt in and cheaper than any other options...
The GM 6 port selector valve is also a good option and gut the intank pumps...
1995 Ford F350 XLT CC LB 4X4, P Pumped 12V, ZF5, D60, Sterling 10.5, SDX 5X14 Injectors, 63/68/12, 175 Pump, mack plug, .024DVs, AFC mods, 100 plate, 4GSK, Studs and O rings, 60LB springs, Colt Cams Camshaft, Southbend clutch, PSD Intercooler, Autometer Gauges
Mr. Bob is offline
post #4 of 32 (permalink) Old 03-02-2010, 07:56 PM
Offroad_Addiction's Avatar
I'm interested in the 6 port GM valve, do you have any other info? Is is from the 80's or early 90's trucks.
Offroad_Addiction is offline
post #5 of 32 (permalink) Old 03-02-2010, 09:29 PM
Mr. Bob's Avatar
Google pollak selector valve.. That is a 6 port electric selector valve.. I had one till I came across the PSD parts truck... You should find all the info you need...
Mr. Bob is offline
post #6 of 32 (permalink) Old 03-02-2010, 10:35 PM
cliff-1972's Avatar
I am not going to use my selector valve set up.When I had the hopped up 7.3 PSD in my truck I did away with it and tied the front tank to the rear tank w/a -12 hose.I did away with the factory pick-ups on the sending units also.I picked up from the front tank w/ -10(5/8) tube and hose and returned to the rear with a -8(1/2) hose.So the rear tank just fills the front as it goes down.It works real good.
1996 Ford F250 reg cab 4x4 98 12v,benched pump,Weston 5x.016,o-ringed,cammed,compounds,etc....E4OD,4.10's on 315/75/16 Dura-trac 563hp 936ft.lbs. 7/26/14 with 5 psi fuel pressure
cliff-1972 is offline
post #7 of 32 (permalink) Old 03-02-2010, 10:47 PM
I was thinking the 2 tanks with the selector would be great if I would use Veg. oil later down the road. I could use one tank for the veg. and one for the diesel.
I have a 88' 7.3 truck, I haven't looked but was assuming the tanks, senders and switching valve would be what I would want for my swap.
David
post #8 of 32 (permalink) Old 03-02-2010, 10:50 PM
Mr. Bob's Avatar
David
Either the pollak one or the factory ford one will work fine... There seem to be lots of parts trucks for sale and these part dont seem to be in high demand...
Mr. Bob is offline
post #9 of 32 (permalink) Old 03-02-2010, 11:50 PM
Originally Posted by Mr. Bob View Post
Either the pollak one or the factory ford one will work fine... There seem to be lots of parts trucks for sale and these part don't seem to be in high demand...
I already have this parts truck, so that's what I'll use. I was thinking so, just like to be reaffirmed.
post #10 of 32 (permalink) Old 03-03-2010, 12:16 AM Thread Starter
Thanks for the info guys. I think I’ m going to take the selector valve off an older truck and replace my tanks with a set I have from a diesel. I found some wiring threads on ford trucks and it looks like the wires are the same weather it has a selector valve or a selector switch. Or there close enough that I can make it work. I might be starting this swap sooner than expected went to start my truck tonight and no start. If its anything major I'm just going to start the swap. I was hoping to start it next month. This truck is my plow truck so I hope it doesn’t snow. I haven’t even ordered my adapter plate yet.
Dillon is offline
post #11 of 32 (permalink) Old 03-03-2010, 09:43 AM
The Destroked plate I ordered came in in a little over a week. Pretty good turn around and a very nicely milled piece.
David
post #12 of 32 (permalink) Old 03-03-2010, 02:56 PM Thread Starter
I'm getting my plate from ford cummins. I like that I can use the dodge starter. Its cheaper to replace. I'm going to get engine mounts from them too. I called them today and left a message waiting to here back. Destroked doesn’t have mounts listed on there site for the obs ford. I went out this morning and my truck fired right up. I don’t know why it would not start last night. It worries me more now not knowing if it will do it again. I still have to pull the cummins out of my parts truck and fix the leaky gaskets, kdp, and paint it. Probably next week.
Dillon is offline
