1951 GMC 12 Valve - Dodge Cummins Diesel Forum
 1Likes
post #1 of 31 (permalink) Old 01-19-2017, 10:01 PM Thread Starter
txag10's Avatar
1951 GMC 12 Valve
I have a 1951 GMC 350 that was used to haul grain and cotton. It was my grandfathers, and then my dads and I would like to get it back on the road. I have a 2004 2500 SCLB 4x4 with a 6 speed that I want to put the GMC body on. The motor in this truck is bad. I got a 1997 2500 2wd with a 5 speed in it for a motor donor. My question is will the 12 valve mount up to the NV5600. I have many more questions on other stuff with both trucks but I would appreciate and help getting started here. Thanks in advance.
txag10 is offline
post #2 of 31 (permalink) Old 01-20-2017, 07:37 AM
Moderator
9297oldram's Avatar
You'll have to use the NV5600 adapter plate and clutch assembly.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/18.5
9297oldram is offline
post #3 of 31 (permalink) Old 01-20-2017, 03:58 PM Thread Starter
txag10's Avatar
Thank you. Do you happen to know what the plugs are for that are on the 4500 and 5600
txag10 is offline
post #4 of 31 (permalink) Old 01-20-2017, 04:00 PM
Moderator
9297oldram's Avatar
Not sure what plugs your talking about?
post #5 of 31 (permalink) Old 01-20-2017, 04:45 PM Thread Starter
txag10's Avatar
1951 GMC 12 Valve
These are from the 4500. The 5600 has a plug similar to the picture without the circle.
[IMG]https:uploads.tapatalk-cdn.com/20170120/a26884307d29008d412e29f8d7ffd7d5.jpg[/IMG]
txag10 is offline
post #6 of 31 (permalink) Old 01-20-2017, 04:49 PM
Moderator
9297oldram's Avatar
It's kinda hard to tell where they are but if they are in the tailshaft section I would say the speedometer. Is there a fork like piece that holds that assembly into the case?
post #7 of 31 (permalink) Old 01-20-2017, 07:14 PM Thread Starter
txag10's Avatar
First three pictures are of the 4500
These are of the 5600 and 241 d transfer case. I assume the one in the transfer case is to turn the 4x4 light on. The truck that has the 5600 also has a sensor on top of the rear differential.
[IMG]http://uploads.tapatalk-cdn.com/20170121/600615f4a1bef995e387f532d347ccc8.jpg[/
txag10 is offline
post #8 of 31 (permalink) Old 01-20-2017, 07:18 PM
Moderator
9297oldram's Avatar
2nd picture should be for the speedometer, 3rd picture should be the reverse lights.
4th picture possibly the reverse light.
txag10 likes this.
post #9 of 31 (permalink) Old 01-20-2017, 07:35 PM Thread Starter
txag10's Avatar
Thanks for your help. I plan on unbolting the 12 valve from the 4500 and trying to get it hooked up to the 5600 tomorrow morning.
txag10 is offline
post #10 of 31 (permalink) Old 01-20-2017, 08:21 PM
Moderator
9297oldram's Avatar
How about a picture of the 51?
post #11 of 31 (permalink) Old 01-21-2017, 11:27 AM Thread Starter
txag10's Avatar
It's pretty rough but the price was right. Going to replace the floor and the rear cab corners. The roof and the hood are going to need some bracing. The plan is to also build a skirted flatbed and top it with some nice wood.
txag10 is offline
post #12 of 31 (permalink) Old 01-21-2017, 12:03 PM
Moderator
9297oldram's Avatar
Must not be from up north or it wouldn't be looking that good.
