| Cummins Conversions - Shop Talk - Tools - Fabrication Discussion Of Cummins Conversion Projects, Tools , Tool Boxes , Garages , Shops , Fabrication ect...NO ADVERTISING |
putting Cummins in 2003 Ford, HELP
![]() here is the truck im going to buy as soon as mine sells, it has a melted 6.0 with a 6 speed manual, what all is going to be involved in puttin a common rail into it? i would LIKE to put an automatic in it! is that possible or would that be too hard? also which transfercase should i use, the one already in the ford, or get one out of a dodge to go with the motor and trans? what all needs to be done with the wiring harness, is there a way to use at least some of the factory ford gauges? i want to make this a clean swap with a common rail and auto, will that be too hard? or should i just get a cummins that has an ecm and harness for a manual and reuse the 6 speed thats already in the ford? Thanks, Andrew
03 Dually with Smarty W/ TNT, FASS 150/150, Stage 1 CP3, K&N, 6 speed W/ Prototype Single Disk Feramic Clutch, Boost Elbow, 2" leveling kit, 295/70/r17 Nitto Terra Grapplers, A-Pillar Triple Gauge pod |
#2 (permalink) |
your best bet would be to get a donor truck so that u have everything. the easiest thing would be to keep the manual. putting the auto is possible. depending on how u hook it up will be very diddcult. If you want the shifter on the column u will need to install a steering column out of and auto, or i think that u might be able to buy a ratchet shifter for it. I would go to destroked get and adapter plate for ur zf6 and bolt the cummins to that. Alot less headache. my $.02
94 Dodge 1500 black regular cab 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg (Friends) 95 Dodge 2500 4x4 boost elbow (35psi) #6 fuel plate http://www.cumminsforum.com/forum/cu...ics-truck.html |
#3 (permalink) | |
#4 (permalink) |
i say the nv5600 is a better trans. Though a friend of mine has a zf6 with a 5.9 bolted to it with 600hp and seems to be holding fine so far. before the 5.9 he had 2 powerstrokes blowup that were putting out 450hp. The only thing he has done to the trans was a dual disk clutch with pliot and throw out bearing
#5 (permalink) |
scratch the project for now! truck i was lined up to buy, the guy decided to keep it! dont blame him though, a fully loaded 03 for $5,000 so im in the hunt for another 2000+ Ford with a blown motor! if anyone knows of one let me know!
#6 (permalink) |
keep ur eyes open not hard to come by ![]()
#7 (permalink) |
I had a nv56 for 130,000 miles in my 04 dodge, it was my favorite manual tranny and I have had a couple zf six speeds. I am using one now in my 08 550. I have a 2000 ford short crew and a 2005 short crew I will sell, 05 has been wrecked, and the 2000 has miles on it. I have a core 2007 5.9 to help fab the mounts and both trucks have automatic trannys. I dont have time to to the swap right now.
08 5500 single cab 4x auto PTO hydraulic wormdrive tulsa winch. tailroll and ginpoles, and coulple other brand 550 trucks. |
#8 (permalink) |
pics of the wrecked 05! ;-)
