| Cummins Conversions - Shop Talk - Tools - Fabrication Discussion Of Cummins Conversion Projects, Tools , Tool Boxes , Garages , Shops , Fabrication ect...NO ADVERTISING |
#2 (permalink) |
Use a ford or winch solinoid on a switch.
79 F-350 sc.flat bed,dana 60 front dana 80 ltd.slip rear.95 cummins/5spd and transfer case.custom ground #10 plate.
#4 (permalink) |
Cummins Crazy
![]() Join Date: Jun 2007
You will need a solenoid. I am not sure what the amperage is. Switch on one side and the battery cables to the heater on the other
My truck: 06 5.9 G56 4x4 Quad Cab Short Bed Patriot Blue. Smarty TNT, Valair 3600DD, DiPricol's, Home made intake w/ amsoil filter, Straight Piped w/ 7" tip, silencer ring MIA, glove box sticker MIA 2/28/09-470hp/980tq IBEW 551-PACIFIC COAST DIESEL |
#5 (permalink) |
![]() There, I made you one of my (in)famous diagrams.
1978 Bronco - 1991 12V, Dynamic C6 Ford auto with billet torque converter, NP205 case, 3.50:1 lockers. 9" lift, 35" tires, 366 spring, pump mods. - Still under construction. |
#6 (permalink) |
nice diagram, that helps me out too, do u need to put a fuse in their somewhere and if so what amp?
96 12v 215 P-pump, kdp done, silencer ring mod, bd diesel boost elbow, 60lb intake/exhaust springs, 4k gsk and soon to be in my 1995 F250 On the bench-afc spring kit, 100plate and 16 degrees of timing |
#7 (permalink) | |
#9 (permalink) |
I would use a momentary toggle switch. It may not seem too bad but your finger will get tired trying to hold the push button in for 30 seconds at a time. I used to drive a truck with a Murphy switch setup. When it had a hard time starting you had to keep the override pushed in. I would have changed it but it wasn't my truck.
1965 Ford Crewcab 4x4 currently undergoing a 12V conversion. See it in the conversion section. |
#10 (permalink) |
thanx i plan on using a push start switch. i forgot once to turn off my fuel heater on my wvo system and totally killed my batteries
#11 (permalink) |
I forgot to draw in the circuit breaker, but I'm putting it between the solenoid and the heater, in case something bad happens, it will kill the power to it. For the light, I'm just running a wire from the grid heater positive terminal to the dashboard. Since I'll be using the heater for 30 seconds or more, I'll pick out a switch that's really easy to push.. Actually a footswitch might work good, too, if I can find a spot for it.(already have the headlight switch down there)
1978 Bronco - 1991 12V, Dynamic C6 Ford auto with billet torque converter, NP205 case, 3.50:1 lockers. 9" lift, 35" tires, 366 spring, pump mods. - Still under construction. Last edited by American Thunder : 11-07-2009 at 06:37 PM. |
#12 (permalink) |
FYI the grid heater elements will draw 95amps a piece @ 12v (higher if the voltage drops), make sure that you use a solenoid(s) capable of handling this.
97 Ram 2500 / 5.9ctd /NV4500/241DHD Custom Intake Tube+ BHAF, Pump Tuning, Autometer Pyro and Boost gauges, Dual 4" stacks, 33x12.5 Mud terrains, posi-lok, One Hella sound system, tons more to come
| The Following User Says Thank You to ykdave For This Useful Post: | Cummins6speed (11-10-2009) |
