1. I believe so, but can't properly validate.
2. see 1.
3. Yes, most definitely. The starter location is different, as is the bolt locations.
4. You would need the proper adapter, as the manuals use a different adapter plate than the autos, then the obvious pedal and hydraulic clutch setup to deal with. Not to mention, from what I heard, the parts are hard to come by if needed as New Venture is no more...
5. Suggestions... find a first gen trans and t-case,a s they still had the output shaft for the front on the same side as your Chevy. I don't know what year they changed, but the later cases match Fords.
1992 F350 crew cab 2wd, 1992 Cummins, NV4500 5 speed, Gear Vendors overdrive
