85 chevy 5.9 swap ?s - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 10-19-2009, 02:02 PM Thread Starter
i have an 85 chevy with a four speed granny runnin one ton gear. my question is would i be better off to use a dodge manual instead of trying to retro the chevy driveline to the cummins and save money that way. i plan to use a pro fab t case instead of my 205 any ideas or thoughts will be greatly appreciated this truck is going to be a puller not street driven so that is why i ask about trans maybe run a direct drive gear what would be best thank you much
1985 chevy regular cab long bed one ton axles, 12valve, five speed moderate engine build in progress conversion to cummins pulling truck
dieselburner87 is offline
post #2 of 3 (permalink) Old 10-20-2009, 09:13 AM
JakeDiesel's Avatar
if by dodge manual u mean the nv4500 i think that u will be better off with the nv4500. 1 they are a good trans and u will have od with the 4500 compared to the 4 speed which doesnt. with a manual u can put it in any gear u want and leave it there u dont have to use the od.
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude. 01 f650 with 5.9 cummins. 06 2500 all stock for now
JakeDiesel is offline
post #3 of 3 (permalink) Old 10-22-2009, 04:34 PM Thread Starter
well i dont need the od unless it is direct i dont know much about dodge i figured it would be easier to use dodge stuff instead of converting to my chevy transmission i figured a good clutch would hold up better and be cheaper than a automatic
