6.7 Crank in 5.9? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 08-19-2009, 01:07 AM Thread Starter
6.7 Crank in 5.9?
I have searched, and have yet to find a definitive answer; Can a Gen 2 12 Valve be bored and stroked to a 6.7? I'm not interested in putting a p-pump on a 6.7 or swapping heads, I want to know if a 6.7 crank, rods and pistons cold be put into a 5.9, and could the 5.9 block be bored out enough to fit the 6.7 pistons? For that matter, could an aftermarket stroker crank be had for a 5.9, and how far can you bore a 5.9? Thanks.
buckshot305 is offline
post #2 of 7 (permalink) Old 08-19-2009, 05:25 PM
JakeDiesel's Avatar
I believe that the cr 5.9 and the 6.7 use the same head. I might be easier to p pump the 6.7. Home Page
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude. 01 f650 with 5.9 cummins. 06 2500 all stock for now
JakeDiesel is offline
post #3 of 7 (permalink) Old 08-19-2009, 08:39 PM Thread Starter
That's what I've found also, but I would like to know if a 6.7 crank could be used in a 5.9 6BT. Or are there aftermarket stroker kits that could be used?
post #4 of 7 (permalink) Old 08-20-2009, 06:09 PM
JakeDiesel's Avatar
There is a thread on this in the 94-98 preformance section that might help u.
post #5 of 7 (permalink) Old 08-26-2009, 08:06 PM
Suffers from Black Lung
Cumminpwr11's Avatar
Jake do you have the link?
Chris
1997 Ram 3500 crew cab long bed dually NV4500 GDS-300 62/65/12
1936 Chevy pickup 4bta rat rod project build
2006 Jetta TDI 5spd 45MPG commuter
2005 Ford Excursion 6.OH Livewire TS+
2003 Chevy 3500 cab chassis Duramax LB7 all stock
Cumminpwr11 is online now
post #6 of 7 (permalink) Old 08-27-2009, 04:07 PM
JakeDiesel's Avatar
cummins stroker kit
post #7 of 7 (permalink) Old 08-27-2009, 04:18 PM
farmtwin's Avatar
The 6.7 Crank will not fit in the 5.9 block the 6.7 blocks are wider then the 5.9 blocks to make room for the extra stroke
2006 Mega 6sp mostly stock for now...
farmtwin is offline
