| Cummins Conversions - Shop Talk - Tools - Fabrication Discussion Of Cummins Conversion Projects, Tools , Tool Boxes , Garages , Shops , Fabrication ect...NO ADVERTISING |
project cummins trail duster (ctd)
long story short i been wanting to do this swap for over 2 years now. the truck 1979 plymouth trailduster ![]() the engine 1994 cummins turbo diesel with 47rh with 277k on the odo. found it on craigslist for 500 ![]() ![]() ![]() ![]() i got dana 60's for the front and rear and a np205 for the tcase. and from the looks of it im gona need new front springs ![]() and need a new radiator core support that will house the hugenormous radiator and intercooler that i got off the parts truck ![]() i did some measuring and i think im gona have to find the block adaptor for the 89-93 engine mounts. any one got the part number? mod list kill the kdp 4 inch exhaust electric fan conversion tune the pump up to 230hp so what you guys think
1979 Plymouth TrailDuster 94 cummins turbo/47rh/np205/ d60 front and rear http://www.cumminsforum.com/forum/cu...uster-ctd.html |
#2 (permalink) |
that is going to be a sweet swap!!!!! keep us posted on the progress and lots of pics!
1987 FORD F250 EXT. Cab 6in lift 37's on 20inch rims. D60 swap. Was 6.9/C6. now p-pump 12v 4k gsk,custom pump work , s300, Southbend clutch, nv4500. 1996 reg cab 5 speed 4x4 12v 35's. 1994 cummins 2wd built auto tranny 3k gsk 4inch exh custom fuel plate . 97 TL1000s |
#4 (permalink) | |
actually i got the motor with turbo tranny inter cooler radiator wire harness and computer all for 500. granted im not gona use the harness spet for a few plugs or the computer.
#5 (permalink) |
ops forgot to post the vid of how i got the engine /trans http://www.youtube.com/watch?v=PkiLpwLW8B4
#6 (permalink) |
HELP FIGHT CA SMOG REGS!
[quote= i did some measuring and i think im gona have to find the block adaptor for the 89-93 engine mounts. any one got the part number? /QUOTE] build your own, they are easy.
08 Chevy LMM 6" lift 20" monsters w/35's, other than that all stock. 69 Chevelle, BB 427, Ported and polished heads, Custom cam, 10.5/1 compression, Forged TRW pistons, 1.7 Roller rockers, Holley 750 double pumper, Stage 2 TH 400, 12 bolt rear end |
#7 (permalink) | |
i would but i have 0 fab skill. and i dont want the engine to fall out on me on the free way. that and i want the engine mounts to sit on the cross member. with the mounts i have now they will either mount just behind the member or move the engine to far forward to mount the core support and using the 92-93 block mount allows me to use more of my factory stuff and save me money. now i say this because im not the first or the last person to do this. a guy over on rcc did it to a 78 with the 93 ctd and use the factory mounts and it just bolted in Quote:
RamchargerCentral.Com - - 78 'Nacho'
#8 (permalink) | |
#9 (permalink) |
well it stopped raining long enough for me to get some more work done. draind the engine trans and radiator, and pulled the radiator core support. hopefully if its not raining tomorrow i can start pulling the engine.
#10 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
Your going to need to bend the left side frame rail upper flange where the starter is going to be setting. The starter sets at a different angle with the second gen engine adapater. It will hit the frame. If you look in the 1st gen for sale section you should be able to find someone parting out a 1st gen to get the engine mounting blocks from. FarmerFred was parting a 1st gen engine a while back.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#11 (permalink) |
thanks for the input. i am gonna stick with the 2nd gen adapter plate. mainly cause i have a lockup torque converter and the first gen doesn't
#12 (permalink) |
sweeeeet ![]() keep us updated dude
CJ's truck....got a problem w/ your VP powered truck?? click===>>this link 02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up... |
