1977 powerwagon-diesel - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 02-14-2009, 03:19 PM Thread Starter
1977 360/np435/203. looking for info to make bolt in.
have 1991 6bt complete with flywheel and bellhousing.
want to keep trans,t-case. any info for off the shelf
parts. clutch and new bellhousing? will be used on farm
no heavy pulling or towing.gofor stuff truck. lakewood
dosn't make diesel bellhousings. I have parts for hyd.slave
in if needed. I know engine will drop in frame with no problems. I all ready did a 1985 ramcharger 4x4 conversion
6bt auto/od. was a bolt in with few mod.s
frtendtech is offline
post #2 of 4 (permalink) Old 02-21-2009, 07:21 PM
as you get this 6bt into the 1977 powerwagon
please keep posted as to the modifications needed and componets used
good luck & thanks
willin is offline
post #3 of 4 (permalink) Old 08-16-2009, 11:54 AM Thread Starter
1977 w400 cummins conversion
stock 89 bellhousing had center hole bored to fit np445
got 12 clutch from parts store(picked buy size and splines)
stock pilot bearing,throw out was stock from clutch kit.
as it fit stock fork from 89 bellhousing,had fly wheel drilled
to fit new pressure plate that came with clutch kit.power
steering hose,changed fitting at pump,swapped oil pressure
temp senders,opened wireing harness remove ignition circits
wired key on power to pump. everything so far is bolt in!
still in process of clutch slay and master,core support for
rad and inner cooler.
post #4 of 4 (permalink) Old 08-16-2009, 10:21 PM
JakeDiesel's Avatar
sounds like a cool swap will have to post pics
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude. 01 f650 with 5.9 cummins. 06 2500 all stock for now
JakeDiesel is offline
