| Cummins Conversions - Shop Talk - Tools - Fabrication Discussion Of Cummins Conversion Projects, Tools , Tool Boxes , Garages , Shops , Fabrication ect...NO ADVERTISING |
#25 (permalink) | |
Prestige Worldwide
![]() Join Date: Oct 2007
1969 Ford Crew Cab Cummins Conversion... http://www.cumminsforum.com/forum/cu...-crew-cab.html |
#26 (permalink) | |
Prestige Worldwide
#27 (permalink) | |
As far as getting done before you, who knows. I hope to have it done in 4 weeks or so, but I work one week on one week off, so I probably have a little more time to work on it. |
#28 (permalink) | |
#30 (permalink) | |
Prestige Worldwide
Poly mounts are used in many extreme aftermarket applications... as far as durability, I think they are fine! And good welds will help.... ![]()
#31 (permalink) |
Here are the pics of the roof. There is no obvious seam, but it is pretty dirty. ![]() ![]() ![]() Here are my motor mounts installed on the engine, they will be boxed in later. First I leveled the truck frame my gargae floor is sloped towards the middle. I laid the motor back 3 degrees, and leveled it side to side. ![]() The engine side of the mounts were bolted to the engine and the frame standoffs were measured. They were cut, then welded to the tube that my poly bushings fit. ![]() The poly bushings were put in the tubes and tubes and standoffs were tacked to the frame. ![]() ![]() After I was done I found out I did not measure good enough and the motor is off center at the transmission a inch or so. I will have to remove the passenger side mount and retack it. |
#32 (permalink) |
Prestige Worldwide
Ya, that roof doesn't have any bracing! ![]() Mounts are looking good!
1969 Ford Crew Cab Cummins Conversion... http://www.cumminsforum.com/forum/cu...-crew-cab.html Last edited by HRDROKN : 01-25-2009 at 03:22 AM. |
#33 (permalink) |
looking good!
My cummins swap - 1974 Ford Crew cab http://www.cumminsforum.com/forum/cu...-crew-cab.html |
#34 (permalink) |
I made some more progress today. I am making the transmission crossmember. Here is the stock Dodge piece. I thought about using it but decided to make one from scratch. ![]() Here is what I have to work with. I am going to use the same poly bushing that I used on the motor mounts. ![]() I used a hole saw and cut a hole that the tuning fits in. I then cut it in half. This gave me two saddles for the tube to sit in. ![]() I made a plate that matches the bolt pattern on the back of the trans. ![]() The I welded it all up. ![]() ![]() ![]() I used some 2x4 1/8 wall tubing for the crossmember. I made the part that bolts to the transmission first. I made some ears to fit the poly bushing and tacked it on. Here it is bolted up. ![]() I will box 10 inches of the frame and weld the crossmember in. |
#35 (permalink) | |
That's just me though, and is probably why my projects take so long. I am overly anal and take too much time on everything - haha.
#36 (permalink) |
More progress today. I worked on the transmission crossmember. I boxed in the frame where the crossmember will be going. ![]() ![]() I need to know the angle of the side peices so I can make them line up. I use the square and the angle finder. This one was 30 degrees, which makes it easier. ![]() ![]() I use a horizontal band saw for this. I am using 2x4 box tubing. Set the fence to cut 30 degree angle on one end. ![]() ![]() In order for the tubes to line up when done the angle must be split in half and that half needs to be taken off each tube you want to join. In this case it's 15 degrees. ![]() ![]() The 15 degree cut needs to be done on the middle peice as well. ![]() Here it is on the bench. ![]() Tacked in place. ![]() I thought about making is bolt in, but this one should not be in the way when I go to pull the engine out. I also got my motor mounts boxed in. ![]() ![]() Next I need to make the crossmember that goes under the motor. That one I will make it bolt in. |
