Dodge 1500 4x4 4BT - Dodge Cummins Diesel Forum
Cummins 4BT A forum just for the 4cyl cummins.
post #1 of 111 (permalink) Old 09-02-2012, 10:49 PM Thread Starter
Moochoff's Avatar
Dodge 1500 4x4 4BT
VIDEO'S ON PG.8
Hey guys,
Finally started the 1500 project ... I am a few days in but have plenty of pics and such. All questions, comments and advice are welcome
Truck is a 1998 Dodge ram extended cab. 5.9 magnum, 46re tranny, stock tcase...
Moved on to smaller toys.
Moochoff is offline
post #2 of 111 (permalink) Old 09-02-2012, 10:56 PM Thread Starter
Moochoff's Avatar
I pulled the bed to tinker with the failing fuel pump. Im going to add a draw straw and return line. Lift pump on the 4bt is mounted on the back of the block and wont need the 12v hot wire...
The girlfriend cleaned her new tranny and we got it painted up...
Pulled the old 360, tranny, tcase all in one shot. Looked like a jet on take off lol
Moochoff is offline
post #3 of 111 (permalink) Old 09-02-2012, 10:58 PM
insanity05's Avatar
GL with your build subscribing.
Incredible Orange Turd its orange.09 Kia Rio 5 speed. Aftermarket cruse control.
Buick 2016 Buick Verano its blue, really nice car.
BIGPIG 05 2500 long gone.
I have a stupid and know how to use it!
insanity05 is offline
post #4 of 111 (permalink) Old 09-03-2012, 09:43 AM
JakeDiesel's Avatar
Originally Posted by Moochoff View Post
I pulled the bed to tinker with the failing fuel pump. Im going to add a draw straw and return line. Lift pump on the 4bt is mounted on the back of the block and wont need the 12v hot wire...]
Just cut the one wire that that goes to the fuel pump leave the rest so that your fuel gauge will still work. You have a 4bt yet? Saw it on compd.
4bt is not to small for that truck. My complete stock engine moves my truck just fine. And if you want more power, you can easily make 250 hp with a 4bt giving it almost 100hp more than 5.9s came from factory. IMO the only advantage of a 12v is price. Good Luck with it.
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude. 01 f650 with 5.9 cummins. 06 2500 all stock for now
JakeDiesel is offline
The Following User Says Thank You to JakeDiesel For This Useful Post:
Moochoff (09-03-2012)
post #5 of 111 (permalink) Old 09-03-2012, 11:07 AM Thread Starter
Moochoff's Avatar
Thanks for the encouragement
Did you ever get your tach and mph to work?
Here's after I pulled the motor and trans... Cleaning them up. Selling the 46re to a buddy
Girlfriend took a funny picture of me havin a beer and looking stupid
Moochoff is offline
post #6 of 111 (permalink) Old 09-03-2012, 11:21 AM
ghostman's Avatar
iTrader Score: 6 reviews
Very cool. Interested to see how it goes.
Sent from my Autoguide iPad app
Two second gens with lots of mods and a 3rd gen just getting started
ghostman is online now
post #7 of 111 (permalink) Old 09-03-2012, 08:11 PM
JakeDiesel's Avatar
My dash doesnt have a tach in it. I got a tach out of an IR roller and put it on my dash.
post #8 of 111 (permalink) Old 09-05-2012, 12:44 AM Thread Starter
Moochoff's Avatar
46re is just a baby when sits next to the 47rh
Looking around for somewhere to cut my driveshafts... Im thinking my splines are gonna be a PITA too
Moochoff is offline
post #9 of 111 (permalink) Old 09-05-2012, 03:52 PM Thread Starter
Moochoff's Avatar
Question
Was the 46rh you used in your swap already in the truck?
I also want to run new fuel lines from a draw straw setup. Would 3/8" line be ideal for the 4bt?
Moochoff is offline
post #10 of 111 (permalink) Old 09-06-2012, 09:03 AM
JakeDiesel's Avatar
No the rh came out of a 91 350 with a 5.9 in it.
I used 3/8s line with a draw straw also.
Moochoff (09-06-2012)
post #11 of 111 (permalink) Old 09-06-2012, 02:49 PM Thread Starter
Moochoff's Avatar
Well I took the driveshafts out of my 1500 tcase (231)
The rear shaft's slip yoke slid right in the 241dld on the new 47rh, and the front shaft bolted up also. That saved me a mess trying to find 2500 shaft ends for the new setup.
32 teeth on the rear and four 7/16"? bolts on the front shaft.
Picking up some fuel line and see if the parts store has the transmission cooler line connectors I need.
Since I wont be towing, and will be using a lock up switch, Im going to try and get away with using my small 46re cooler. Ill get a temp sensor plugged in before I add the fluid
Moochoff is offline
post #12 of 111 (permalink) Old 09-07-2012, 12:16 AM Thread Starter
Moochoff's Avatar
Update, didn't get much done tonight due to other things going on.. But I pulled the trans crossmember the rest of the way out and set it under the 47 to make sure it would fit. Painted the rest of the trans
I also got my 3/8" fuel line on the way along with another haynes manual. O Reillys employees what a joke....
Crossmember has slots for the mounting bolts which may come in handy for the 47 and its new driveshafts. Hopefully there will be room for small error in the measurements
Moochoff is offline
