Go Back   Dodge Cummins Diesel Forum > Specialty Forums > C&C / DRW
C&C / DRW Discussion of the Cab & Chassis and Dual Rear Wheel trucks.
Old 11-03-2009, 02:00 PM   #409 (permalink)
TexasCummins's Avatar
Originally Posted by Moparman View Post
Ummm...too much information.
I think he means he wants to spend more $$
Franco R., "Garmin" // Texas Chapter Events Calendar
1991.5 D350 - 5-speed, RC, BHAF w/ prefilter, fuel pin 90*, 5" Aussies, boost gauge, 12cm housing
On order/in progress - EGT gauge
TexasCummins is offline   Reply With Quote
Old 11-03-2009, 02:36 PM   #410 (permalink)
04SSHD's Avatar
well, I have the rims, just need adapters and tires!
07.5 Dodge Ram 3500HD SLT 6.7L,11/06 build,5/08 delivery,PMT,DPF & EGR fell off,G56,4.10 (3.73 soon),C&C,HBS,5000k HID Solutions lights & fogs,14,000 miles to date,37" M/T,22.5's soon,Dyno at 445hp/907tq
04SSHD is offline   Reply With Quote
Old 11-04-2009, 05:47 AM   #411 (permalink)
Any reason no one is using the 275/70R22.5 tires? They are about an inch wider than the 255/70 and about 38" tall.
DANSDUALLYS is offline   Reply With Quote
Old 11-04-2009, 12:12 PM   #412 (permalink)
Performance's Avatar
Well, the 255/70s are easier to find and the cost is cheaper. I don't know of anyone that has tried a 275/70, but Im going to say they will probably be to wide even at just 1" wider. One clearence issue is the rear leaf springs. You can just get a finger between the tire and leaf spring using a 255/70, so anything wider and its going to rub. Also, you would need a lift to help with clearence in the front and I believe the tires will still rub the control arms when turning. I know guys with lifts can clear much bigger tires, but the Alcoa wheel offset and the adaptors just dont allow enough room. Now, with that said they may fit perfect. Don't know, cause I haven't tried. The 255/70s just seem to be the best size for cost, fit, and without any problems over time.
2006 DODGE RAM 3500 - Silver, Reg. Cab, 4x4, Dually, 6spd, Quadzilla X2 Race Module, CFM+ Intake, AEM Workhorse Intake, Banks Monster Dual Exhaust, MBRP Cat. Delete Pipe, Isspro Gauges, Air Horns, ReadyLift Leveling Kit, 22.5" Classic Alcoas, 255/70 Sumitomos.
Performance is offline   Reply With Quote
Old 11-10-2009, 06:48 PM   #413 (permalink)
my 3yr old took this pic while I was washing the rig
mjpage69 is offline   Reply With Quote
Old 11-10-2009, 06:54 PM   #414 (permalink)
TUK
TUK's Avatar
Here is my 04
04.5 QC SB 4WD, EDGE JUICE W/ATTITUDE (HOT 6), EDGE EZ, AFE STAGE 2 INTAKE, AIR DOG 150, 4" to 5" BLACK DUAL STACKS, TRANNY BY ADB, HOPE TO HAVE INJECTORS, WATER/METH, LARGER TURBO AND INTERCOOLER SOON
TUK is offline   Reply With Quote
Old 11-10-2009, 10:15 PM   #415 (permalink)
jr22's Avatar
nice pics tuk !
2008 Dodge Ram 3500 grey with line-x rockers and box. 6.7l cummins 6spd mt 4x4 quad cab long box. 2008 arctic cat m1000 162 track orange,2006 arctic cat 500le 4x4 atv red.2005 bearcat enclosed trailer
jr22 is offline   Reply With Quote
Old 11-11-2009, 03:25 AM   #416 (permalink)
BOWZ's Avatar
Originally Posted by Performance View Post
D. Wigg's truck actually just had a 4" lift in the front and a 2" lift in the rear to clear the 295/75s. Goodyear no longer offers the 295/75 in the G164s on his truck. The 295/75 is actually 40" tall. Now with that said, Wiggs also had much more work done. They moved the front axle forward 1" and he had heavy duty axles made with the 10 lug pattern, so no adaptors. Depending on how much they put the axles out, it gave the tires enough clearence to the control arms. The control arms are the problem in the front with stock suspension. Even with a 6" lift and aftermarket control arms, I still believe the tires will rub when turning. There just isn't enough offset in the wheels or adaptors to allow for that size tire. But I guess if the lift is big enough, like above, they will work. Hope I helped some.
pefomance, thanks for the quick reply, good to know. i will probably just stick with the 37's.
now i had a offer to get 6 steelies to put an intake on this guys truck. i have not seen these 22.5's but he said they had some surface rust. they are free, if i clean em up myself are they worth it? if not how chewed up do the alcola alum. get in salt. worried given i live in AK. thanks!
bowz
2005 RAM 3500 QUAD CAB DRW LB, 4.10, 6SP, EDGE JUICE W/ATTITUDE,SMOKE SWITCH, BULLY DOG INTAKE, BAFFELS AND SILENCER MIA, 7IN MITER STACKS, 6IN LIFT, REAR WHEEL SPACERS, 37X12.5 BFG A/T'S, FASS FUEL PUMP,CLUTCH. THANKS GUS FBD
BOWZ is offline   Reply With Quote
Old 11-11-2009, 11:11 AM   #417 (permalink)
bowz
Well, the steels are definitly worth it for an intake install. But, they are heavy. You will feel the extra weight and power loss that goes with them. They will work, but for the added loss in power and loss in braking, it's not worth the trouble. I just can't justify running 6 steel wheels. The Alcoas are fairly resistant to salt and have a tougher finish compared to most aftermarket wheels, but you have to keep them washed. If you run in salt, try to get it off as soon as you can. Over a period of time, the salt will pit and stain the finish. It's very hard to get the shine back.
ERIC
The Following User Says Thank You to Performance For This Useful Post:
BOWZ (11-12-2009)
Old 11-12-2009, 01:14 PM   #418 (permalink)
Originally Posted by BSouth View Post
did u have to shorten ur axle?
jordangrypuik is offline   Reply With Quote
Old 11-12-2009, 04:42 PM   #419 (permalink)
firemanram's Avatar
That's one is a good looking truck mjpage69 
2004.5 4x4 Dually ,Guages, SMARTY,HTS trans, CAI,19.5" wheels & tires,Quad BF, II Silver 62, Fass 150, dual miter stacks.
DDP 90 hp nozzles will be on soon!
firemanram is offline   Reply With Quote
Old 11-12-2009, 08:10 PM   #420 (permalink)
backwoodsboy916's Avatar
What kinda success do yall have with the commercial tires in mud, now i know they wont do like my Firestone MTs, but im not mud boggin, but when we get 5 inches of rain, like we did tuesday, and i have to go out and check cows, it sure is muddy, not deep, but real slick. A family friend that rents one of our pastures has a F-450 2 door flatbed (V-10), and he runs whatever tires the new UPS trucks run, and he seems to have pretty decent traction off-road, but even though his is a 450, its gas and short, mines a lot heavier. Any info...opinions...
2005 3500, NV5600 4x4, Edge Juice w/Attitude, K&N Air Intake, ATS exhaust manifold, CFM Intake Manifold, Silverline 4" TBE, Silencer Ring MIA, Recon Smoked LED Cab/Fender Lights, 285/70/17 Firestone MT, Valair Ceramic/Kevlar Clutch, DeBadged To be Installed--CM Flatbed Hopefully coming this year--Black Grille/Grille Shell, Black Front Bumper
The Ol' Lady's Ride-2007 2500 6.7 auto, 4x4, Ranch Hand style Front and Rear Bumpers, more to come...
backwoodsboy916 is offline   Reply With Quote
