Go Back   Dodge Cummins Diesel Forum > Specialty Forums > C&C / DRW
C&C / DRW Discussion of the Cab & Chassis and Dual Rear Wheel trucks.
Old 10-09-2009, 04:03 PM   #385 (permalink)
WildWest16's Avatar
255/75/22.5
2004 3500 DRW 4x4---AFE Stg.2---Magnaflow 5" TB---Smarty TNT---FASS SYSTEM---SUN COAST VB, TC, BILLET INPUT---Rollin on 22.5"s
WildWest16 is offline   Reply With Quote
Old 10-10-2009, 10:44 AM   #386 (permalink)
Can 22.5's fit on a 2wd with a leveling kit?
1999 Ram 3500 Quad Cab 2wd Dually: AFE Stg 2 intake, Edge Juice w/ Attitude (Hot unlock),
silencer ring M.I.A, BD Flow-Max Lift Pump, MBRP 4" turboback, SuperChips Flash Pack
SLO_59 is offline   Reply With Quote
Old 10-10-2009, 11:20 AM   #387 (permalink)
Ruthless Racing's Avatar
If you are talking 22.5's with the semi tires, yes the leveling kit should give you enough clearance.
2006 Dodge Ram SRT-6 Mega Cab Dually on 24's
2007 AMA Dragbike 1000SS National Champion!!!
Visit My Page Here
Ruthless Racing is offline   Reply With Quote
Old 10-10-2009, 10:52 PM   #388 (permalink)
Pooter's Avatar
Originally Posted by WildWest16 View Post
255/75/22.5 and ive got a bad shake that starts at 70 mph... cant drive over like 65 on the interstate and it sucks... anybody experience this??????
Any suspension mods? (leveling spacer?)
how are the ball joints/track bar bushings?
Oh, and did you get the tires balanced?
Lots of different things can contribute to "death wobble"
'07 5.9 Mega Cab 2wd/G56
Pooter is offline   Reply With Quote
Old 10-12-2009, 03:14 PM   #389 (permalink)
Originally Posted by BSouth View Post
who makes those wheels? model and size?
Owner - Force Fed Engineering
Home of the Worlds most powerful 4cy vw's
812whp, 511wtq 1.8L 20v.
EdsGTI is offline   Reply With Quote
Old 10-13-2009, 09:05 PM   #390 (permalink)
BigTime's Avatar
looks like we've got a mustang and another car both also yellow. Favorite color? Clean truck btw
2004.5 2500 quad cab Laramie. Banks Power catback, AEM intake, Edge Juice w/ Attitude. More Coming!
BigTime is offline   Reply With Quote
Old 10-13-2009, 09:16 PM   #391 (permalink)
whats a good place to get alcoa 19.5's or 22.5's for 05 dually with tires at a decent price?
hillbillydeluxe is offline   Reply With Quote
Old 10-20-2009, 10:07 PM   #392 (permalink)
Originally Posted by dave@BD Power View Post
My Sleeper
2003 2WD Reg Cab - 5800lbs Wet!
How did you lower it?
2006 2500 2wd SLT LoneStar Ed. bed liner/cover, muffler, K&N Filter.
dhsdodge is offline   Reply With Quote
Old 10-21-2009, 12:12 AM   #393 (permalink)
any pics of guys running just the 22.5 steel wheels all the way around?
ltex old iron is offline   Reply With Quote
Old 10-22-2009, 02:17 AM   #394 (permalink)
Colin Doyle's Avatar
Haha... the truck makes my XR look tiny.
These are Accuride wheels with 255/70/22.5s. No lift or leveling kit. The only clearance issue was up front, where the tires (when turned about half way to lock) would just barely graze the plastic wheelhouse liners in one spot (at the rear, near the running board.) They probably would've worn through eventually, as the wear marks were clearly visible after a couple thousand miles.
I was borrowing these from a friend who was having his '04 straightened out and painted... body guy wanted steelies on it, so I rode around on his 22.5s for a few weeks. They're great on his truck because it's got the four door cab (not the Mega cab, but the shorter one,) but all that unsprung weight seems to make a short wheelbase truck like mine feel a little less surefooted.
I loved the crazy gear reduction effect... I went from 2500 RPMs at 70 MPH to less than 2000 RPMs. 4.10s are a bummer.
I'll probably get some 19.5s when the time comes.
'98 Ram 3500 - RCLB DRW, 4WD, NV4500, 4.10s, #10 plate, 4K GSK, AFC spring kit, 4" exhaust, BHAF, Isspro gauges, 15.5° timing, Phoenix Friction clutch, 2" HBS leveling kit w/Tuff Country SX6000 shocks, 100W Unity spotlight
Last edited by Colin Doyle : 01-19-2010 at 07:57 PM. Reason: The tires' aspect ratio is 70, not 90.
Colin Doyle is offline   Reply With Quote
Old 10-22-2009, 04:58 PM   #395 (permalink)
AMixon's Avatar
Location: South Holland, IL but currently in Baghdad, Iraq
Are you looking at all steel because of the price?
If so I have found reconditioned Aluminum rims that are really, really cheap. Not to mention the weight savings over all steel. I only ask because I was looking at running all steel and after talking to a few folks on here and doing the math (Fuel mileage, extra mass to get moving and slow down) the 4 Alum 2 steel (stays under factory fenders in rear) or all Alum (sticks out 2" per side and requires longer studs on the adapters) is a better way to go
Home These guys are in Illinois near the Quad Cities. Good luck!
Anthony In Iraq
2004.5 QC 4X4 DRW 3.73s Edge and AirDog II for now
AMixon is offline   Reply With Quote
Old 10-22-2009, 05:06 PM   #396 (permalink)
AMixon's Avatar
Originally Posted by Colin Doyle View Post
These are Accuride wheels with 255/90/22.5s. No lift or leveling kit. The only clearance issue was up front, where the tires (when turned about half way to lock) would just barely graze the plastic wheelhouse liners in one spot (at the rear, near the running board.) They probably would've worn through eventually, as the wear marks were clearly visible after a couple thousand miles.
I would LOVE to have one of this small 'SPORT' Dualies as my Daily Driver-I would need all sorts of bail money stored in the glove box and donuts for all of my new law enforcement friends...
Is it sagging in the rear? Just how heavy is that moped anyway?
Anthony In Iraq
