Go Back   Dodge Cummins Diesel Forum > Classified Ads > Buyer/Seller Feedback
Buyer/Seller Feedback NO PERSONAL ATTACKS! Honest feedback only.
Old 09-03-2009, 07:40 PM   #1 (permalink)
wheelin66bronco's Avatar
Geno's Garage
I called technical support at Geno's last week and asked a specific question about a product they sell and was given the answer I wanted, so I ordered the item online.
It arrived today, and to my dismay it was NOT made of the material I had specifically questioned about.
I called Geno's and got Scott. He appologized for the misimformation and fixed the situation. I called a little PO'd and hung up a happy customer that will buy from Geno's in the future. Thanks Scott!!
Oh, and the Dayco replacement tensioner wheel is NOT metal. In fact neither is the gates. You have to buy the whole new tensioner from Gates to get a metal wheel.
05 Dodge CC dually 4x4, NV, BD short shift, Valair Ceramic/Kevlar, Amsoil BHAF, cfm+, guages, Wicked II CP3, Smarty TNT, Quad Fooler-FP guage, AD150, 5" exh, Amsoil Double Bypass, Hankook MT 265/70/17's, flipover ball, Jacobs brake, Nuke Proof Fab Bumper, 123K.
wheelin66bronco is offline   Reply With Quote
Old 10-31-2009, 01:58 AM   #2 (permalink)
cummin not strokin3's Avatar
ya there good guys there i ordered some exhaust tips and they got back ordered so after a few weeks i emailed them to see what the fock was goin on and they said they would just send me some better different tips for the same price so i was happy
1997 dodge 2500 #0 plate 4" exhaust, BHAF, boost and pyro gauges,what silencer ring? 2009 dodge 2500 6.7 stock as he!!
cummin not strokin3 is offline   Reply With Quote
Old 11-03-2009, 08:36 PM   #3 (permalink)
get vert's Avatar
Yup im a happy customer myself
99 Dodge quad cab lb, 24v, ALL CUSTOM
get vert is offline   Reply With Quote
Old 11-06-2009, 08:04 PM   #4 (permalink)
1BadOilBurnerN-Lv's Avatar
Scott's a awesome guy to deal with
2000 2500 sport extended cab short box , 5-speed. 6 inch miter cut stacks , silencer ring M.I.A. , B.H.A.F. 355 gears , 6 inch long arm rcd lift and 37's SuperChips , fass pump
1BadOilBurnerN-Lv is offline   Reply With Quote
Old 11-09-2009, 10:04 PM   #5 (permalink)
97whitecummins's Avatar
only ever ordered once form them, but seems like they have good prices and fast service
97 white 2500 5 speed 4x4, BHAF, 4in. straight pipe, 16* timing, no plate, gutted afc, 5" black aussies, ranch hand front bumper
97whitecummins is offline   Reply With Quote
Old 11-18-2009, 02:07 PM   #6 (permalink)
MTO
Belt was tracking off and went to replace the pulley on the tensioner and also found that the Dayco replacement was plastic so decided to replaced with a Dayco 89016 metal idler/tension pulley. Slightly larger in diameter, worked well.
MTO is offline   Reply With Quote
Old 11-18-2009, 02:09 PM   #7 (permalink)
Northern CA Chapter VP
SmokinTheHippies's Avatar
cant go wrong with Genos.
2002 2500 HO 6 spd 4x4 -433HP- Feb '09 ROTM. Gone to new home!
Thanks Holland Court Diesel!
In search of my next Pig.
http://www.youtube.com/watch?v=axAEF...=youtube_gdata
...."your half a maaaaannn!"
SmokinTheHippies is offline   Reply With Quote
Old 11-18-2009, 03:32 PM   #8 (permalink)
20valve's Avatar
Definitely good guys there. Stopped by Geno's to look at a replacement fuel pump for my '01. We weren't sure if my gauge was hooked up right, so Scott (I think it was him) pulled a fuel pressure tester out and sure enough, 2psi at idle. We also found that my braided line was leaking too, so he hooked me up with one and the fass pump. We swapped the line out in the parking lot, letting me borrow his tools and everything. Definitely helped me out before my 2000+ mile trip!
Budget Build: 98 quad cab 3500 215 pump 3k GSK 0 Plate 16* timing
BHAF 4" pipe. One very tired auto (REMOVED!!!) NV4500 swap in the works Valair 13" Kevlar/Ceramic clutch HE351 swap also in progress
20valve is offline   Reply With Quote
