Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > British Columbia
Old 02-03-2008, 12:57 PM   #1 (permalink)
Miles to Kilometers/Daytime running lights?
Just got my 2002 up from the States. I will have to have my daytime runnning lights activated. Can I do this myself ? Is it something I have to pay lots of money for someone to hook up a computer and press a few buttons?
Also, can I change the odometer to kilometers?
Thanks guys.
Kevin
2002 24V Auto, LB,....soon to have goodies.
Riverjet is offline   Reply With Quote
Old 02-03-2008, 02:05 PM   #2 (permalink)
Ram3500Dually's Avatar
I believe the headlights can be turned on with the Starscan (actually the box before starscan but I forget the name). As far as the odometer I believe you will have to get a complete new head with the KM's on the outside and miles on the inside instead of the exact opposite you have now.
2008 Ram 3500 CTD 6.7/68RE/3:73 LSD
Gone But Not Forgot
2005 Ram 3500 CTD Auto/3:73 LSD AFE CAI,Edge EZ,Kicked the Cat and Muffler, 15.165 @ 89.06 MPH 1/4 Mile at 7560 LBS May/07
Ram3500Dually is offline   Reply With Quote
Old 02-03-2008, 04:45 PM   #3 (permalink)
I have the 2002 shop manual cd, looked it up the other day, it shows a module on left inner fender,
c/p DAYTIME RUNNING LAMP
MODULE
DESCRIPTION
The Daytime Running Lights (Headlamps) System
is installed on vehicles manufactured for sale in Canada
only. A separate module, mounted on the cowl,
controls the DRL.
OPERATION
The headlamps are illuminated when the ignition
switch is turned to the ON position. The DRL module
receives a vehicle-moving signal from the vehicle
speed sensor. This provides a constant headlamps-
on condition as long as the vehicle is moving.
The lamps are illuminated at less than 50 percent of
normal intensity.
02 3500 slt with camper package, 6 speed HO engine 3:54
http://s174.photobucket.com/albums/w98/saab9k/
saab9k is offline   Reply With Quote
Old 02-03-2008, 05:42 PM   #4 (permalink)
Talk to the guys at Canadian tire they are ones that have to certify it if you, give them the Serial number, they can tell you what has to be done. There is a site at Canada Customs that tells you what can be brought in and what is needed. You should have done it before you bought it. The speedo head does not need to be changed Daytime Running lights I believe is a module, you may need bumpers lots of stuff or very little. PLAY SAFE!
JP 3 Licenced HD mechanic for 35 years. RETIRED! worked on engines all my life. Spent last 19 HAPPY years at Freightliner
jpringle3@hotmail.com is offline   Reply With Quote
Old 02-03-2008, 06:22 PM   #5 (permalink)
You can buy a unit at Crappy Tire toturn lites on with the ignition for $24.95.I did this only to find out that on the 3rd series (03 - 07) a Dodge dealer can do it on the truck's computer for about $30.00. It isn't necessary (manditory) to install a panel with km on the odometer.
John
parklane is offline   Reply With Quote
Old 02-03-2008, 08:31 PM   #6 (permalink)
Your right about the module, I wasn't thinking about the 02, I knew the 03 could be activated. As far as the odometer, you don't NEED it but you sounded like you wanted it so thats why I gave you the info on it.
Gone But Not Forgot
Old 02-06-2008, 09:01 AM   #7 (permalink)
Parklane, do you have the part # for the unit from Crappy Tire? I don't mind spending 25 bucks to fix a problem the dealer wants to charge $400 for.
Thanks,
Kevin.
Old 02-06-2008, 12:22 PM   #8 (permalink)
a buddy's truck was from canada. he looked into getting a different gauge cluster and having km/miles converted. it would have been somewhere around like $900 to do it. he just got used to it. money has went into power instead.
2005-2500 Quad Cab Big Horn 4x4 CTD NV5600-4" turbo back-ATS Arc Flow intake manifold-AEM Workhorse HD cold air intake-TST R37-Autometer Phantom II Pyro & Boost-single gauge column pod-SRT10 A-pillar C.I.-27
wintersucks is offline   Reply With Quote
Old 02-06-2008, 12:27 PM   #9 (permalink)
you can jumper the lights to be full on all the time if you like instead of the drl.
the odometer thing can be changed by getting a cluster from a wrecker.
although you get a new odometer reading then as well.
nothing else needs to be changed as far as i know.
00 Dodge Ram 2500 4x4
carter lp,Super B Special, mbrp 4", juice w/att, homemade intake, 33's, three trannies later---> almost enough power
DRFTR is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
