Newbie - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > British Columbia
Old 09-29-2011, 12:48 AM   #1 (permalink)
Question Cam Sensor?
I have a question about my '99 5.9L. Since having my injectors cleaned, on occasion my 'check engine' light comes on and my tach drops to zero. I also have no power (40K tops) if I'm going up a hill when it happens. My mileage has dropped by 25%. Any suggestions on what it might be?
Thanks
Hurricane50 is offline   Reply With Quote
Old 10-03-2011, 01:28 PM   #2 (permalink)
Multiple Codes
Ok, so now I've got some codes to post.
1693
1291
0606
0122
I hope this doesn't mean I've got big problems. I'd appreciate any info you can give me.
'99 3500 5.9L 24V Auto. 4x4 Dually. BD exhaust brake and trans lock
Old 10-03-2011, 01:30 PM   #3 (permalink)
deltadiesel's Avatar
I will ask my dad tonight, he is a diesel technican, see if he has any ideas
1998.5 Dodge Ram 2500 4x4
aFe stage2/4" Magnaflow/rv275/BD FlowMaxx/Quadzilla Adrenaline with Pulse v2/Rough Country 2.5"/8000k HID's
deltadiesel is offline   Reply With Quote
Old 10-05-2011, 12:57 AM   #4 (permalink)
Thundercraft's Avatar
1693
1291
0606
0122
1693 = companion code in ECM
1291 = no temp rise seen from intake heaters
0606 = ECM Failure
0122 = acceleration position sensor (APPS) signal voltage too low
01 2500 SLT Laramie LB
6-Spd 4X4 LB 3.54s
Thundercraft is offline   Reply With Quote
The Following User Says Thank You to Thundercraft For This Useful Post:
Hurricane50 (10-05-2011)
Old 10-06-2011, 12:44 AM   #5 (permalink)
Deanson's Avatar
the tach gets its reading from the cam sensor, but no codes for that. could be a wiring issue between cam sensor and ecm. get that first. Could be a ecm, not super comman but iv replaced a few.
apps sensor could cause a "dead" pedal. does it reset if you turn the truck off/on?
probably not related to your injectors being cleaned though
1997 Dodge Ram 3500 4k GSK, Racked Barrels , 5x.014's,20*,AFC Mods,S400 71/83/.9 ,ARP 12mm studs,5" exhaust,TCS Triple Disk,DTS Tranny,Flex-a-lite fans, LFP9750 oil bypass 13.4@103mph ... I WANNA GO FAST
Deanson is offline   Reply With Quote
The Following User Says Thank You to Deanson For This Useful Post:
Hurricane50 (10-06-2011)
