Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > British Columbia
Old 07-15-2007, 10:59 AM   #1 (permalink)
garyoja's Avatar
deisel shops in bc
looking for reputable diesel shops in the interior of bc we have an ok shop in salmon arm but he is never open when i can get there he closes at 4 or somthing and not open on weekends makes it hard to get work done
01 83000 miles auto triple disc convertor shift kit 6 gear planetarys 35'' toyo tires 3:55 airraid intake 3'' exhaust edge juice bd stealth cover fass
AND A LOOSE NUT BETWEEN THE WHEEL AND THE SEAT
garyoja is offline   Reply With Quote
Old 07-18-2007, 08:34 AM   #2 (permalink)
garyoja's Avatar
nobody else from bc interior or just no good shops wow this forum has been so sloooooooooooooooooooooooooooow
Old 08-28-2007, 09:13 AM   #3 (permalink)
well you have BD In abbotsford, right off the #1, not sure about the interior though, i'm in the lower mainland. Lordco? they can get anything at a good price.
-07.5' 6.7L 3500 QC SB Laramie, Edge Juice w/ Attitude, B/W pocket flares, Diamondback HD toneau, Line-X.
-03 Silverado ECSB turbocharged @ 8psi
cpelton is offline   Reply With Quote
Old 08-28-2007, 10:52 AM   #4 (permalink)
TPS is in chilliwack. They are awsome.
2005 3500 HD 4x4 CDT auto/with custom TPS VB srw AFE stage II DDP injectors (70 hp )Quadzilla STD Rokktech sensor 4'' turbo back exh EGT Boost Trans guages 402 hp 749 tq on the 60hp setting w injectors
syndicate is offline   Reply With Quote
Old 09-27-2007, 05:40 PM   #5 (permalink)
Where is TPS? Friend had work done at Kirkpatricks (?)
Thundercraft is offline   Reply With Quote
Old 11-19-2007, 10:50 AM   #6 (permalink)
Armstrong has a real good Dodge Mechanic. Easy to find right across from Fire Department, "downtown Armstrong". Just ask for Daryl.
Note very busy guy though. To get your work done quickly you may have to sit on Daryl.
wapitiwarior is offline   Reply With Quote
Old 11-19-2007, 11:22 AM   #7 (permalink)
Sales Rep For BD Power
dave@BD Power's Avatar
Yes BD is right off the #1 in Abbotsford, TPS is in Chilliwack, the owner Steve used to work for BD, great guy! Kirkpatrick's is in Chilliwack, again Jeff is one of the head service guys there and used to work here as well, also a great guy! In Kelowna we another ex employee who opened up a shop, the company is Precision Automotive and Jason is our old head R&D tech, good guy!
03 Dodge Ram 2500 2WD Reg Cab
BD X-Tuner stacked with BD X-Power
BD Super-B Turbo & Dual X-Hale Exhaust
BD Max Flow Lift Pump
Ice Box Cold Air Intake
Toll Free 800-887-5030 ext 105 Dave
www.dieselperformance.com
dave@bd-power.com
dave@BD Power is offline   Reply With Quote
Old 12-15-2007, 06:03 PM   #8 (permalink)
06cummins6lift37's Avatar
defitaly bd and there is also i new place in kelowna byt he airport across from codys auctions umm cant remeber the name prices are steep but seems like an alright shop.
06 cummins 6 speed6"lift 37" coopers
bd cold air intake 4inch straight pipe
SMARTY and gauges
06cummins6lift37 is offline   Reply With Quote
Old 12-15-2007, 06:09 PM   #9 (permalink)
I hear Peak Diesel Performance is up that way. New kid on the block, old faces run the place.
sic-and-Fk'n tired of Trolls, CF included.
Good luck all
jefff929 is offline   Reply With Quote
Old 12-18-2007, 05:02 AM   #10 (permalink)
Not at Salmon arm
Hey guys I'm an Alberta boy trying to give ya'all a heads up on PDR, PDR is located in the lower mainland @ Unit #102 - 18910 94th Ave.
Surrey, B.C. Canada
V4N 4C5
A good place and good prices, they also have a USA counter part so when you go shopping make sure you select the canadian shop,
PDR Diesel Inc. The turbo diesel performance specialists! - Home
smokin black is offline   Reply With Quote
Old 12-18-2007, 06:07 AM   #11 (permalink)
Administrator
Graphic Man's Avatar
DTT is also in your neck of the woods
2001 4X4 Q-cab Sport black, full billet DTT trans, billet F-plate Mach 7's, B1-B2 twins, Blue Chip Special X VP, Adrenaline, studded & O-ringed, BD-RAD,Flex-A-Lite electric fans, Autometer Gages, Egt, Boost,Fuel, Oil &,drive pressure, trans temp, RASP, Big line kit, Track bars 2" leveling kit, 271 T-case, DSS, 3rd gen trac bar 623 HP 1175tq with old set-up
Graphic Man is offline   Reply With Quote
Old 02-01-2008, 03:34 PM   #12 (permalink)
dukesofhazzard's Avatar
PDR it is
PDR Piers diesel research will treat you right and they stand behind their work. Speaking from experience.
2002 Dodge Ram 2500 Quad Cab Short Box, SLT Full Load, 6spd H.O.,PDRized HX35 Turbo, 4"MBRP Stainless Exhaust, AFE Intake, Edge Comp,Fass 95/150, Autometer EGT and Boost gauges, 285/75/16 BFG AT's, 06 3500 Badging
dukesofhazzard is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
