shimming the carrier bearing
A couple of days ago I came across a member that had posted in a thread that he shimmed his carrier bearing and that seemed to stop or slowdown the wearing of the u-joints in the driveshaft. I have spent all morning searching for that thread with no luck so! I figured I would ask someone here if they had done the same thing with success. I currently have the driveshaft out and a friend of mine is replacing the u-joints and carrier bearing (he has a shop with tools and press) so I figured that before I re-install the shaft I would do the shim thing if required. A simple piece of aluminum flatbar or heavy walled square tube would work. My truck is stock with no lift or leveling kit installed. However in my searching this morning I did come across a thread in which someone posted that the driveshaft should be balanced after u-joint replacement, this makes sense to me as the driveshaft does spin at a fairly high rpm at hiway speeds! Anyone know of a shop in the langley area that can do this?. I really hate to do things twice and an unbalanced driveshaft would just have me underneath the truck again soon, possibly with more things to fix. Thanks Gary
2004 Ram 3500 Quad Cab SLT DRW, 6 speed manual 4X4....91 F-150 RegCab 4X4 5speed 5Liter Go ahead and cut me off with your pretty little Audi or BMW!! If we connect.........I WIN!! |
#2 (permalink) | |
03 Cummins
![]() Join Date: Apr 2007
03'/305 Dually 4 x 4 HTB2/62/13ss, CFM+ FASS 150, Stage 1 cold air box, BD Intercooler Smarty/Puc stack/TST/Arson III, 60hp.Inj. Goerend Trans. Westach, Fuel/Rail Gauges 547HP & 1000.25 Max Tq. |
#3 (permalink) |
Do you guys have pics of this shimming? I think I am going to have to do it. Can you just loosen something and slide a shim under? I haven't been able to look under my truck due to the weather...Pics would be sweet....Thanks
04.5 3500 laramie, afe intake, magna flow 5" exhaust, airbags in rear, fab-tech lift w/ double shocks up front (dirt logic), w/37's |
