Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > BFXenon.com
BFXenon.com BFXenon.com
Old 10-29-2009, 11:36 PM   #1 (permalink)
Company Name
How-To: Install BFxenon HID Headlights
How-To: Install BFxenon Bi-Xenon HID lights
When installing BFxenon HID lights, for your safety, please remember to remove the battery terminal / positive lead to the battery before connecting any high voltage parts.
Here is a link to the H-13 Bi-Xenon HID Kit:
BFXenon.com H13 series H.I.D. Bi-Xenon light kit - 8000K
Step 1: Remove factory lights from the factory housing
Step 2: Install HID bulb or Locking clip (on some applications) by lining up the channel locks, pushing it into the housing, and twisting.
Step 3: Run the wiring to both sides
Step 4: Connect the female, two wire, terminals on the harness to the ballast
Step 5: Connect the small trigger (two wire) wire from the harness to the bulb and the positive and negative lead off the ballast to the bulb
Step 6: Connect the OEM female headlight connector to the OEM style connector on the wiring harness
Step 7: Attach the ground wire and positive battery lead, re-attach the positive battery connection and turn everything on. This is just to ensure everything lights up properly before you secure the ballasts and wires.
Step 8: Secure the HID ballast within the range of the wiring harness. Some recommended location are; firewall, cold air intake housing (if metal), radiator mounting brace, front bumper brace, etc. (Some of these may not be the best option for every vehicle)
Step 9: Secure all the loose wiring away from any moving parts and out of the way of extreme heat.
Step 10: Enjoy your BFxenon HID headlights!
Before:
After:
For more information or suggestions on how to make these instructions better, please contact: Sales@BFxenon.com
Special thanks to: Industrial Motoring in Anaheim, CA. Check them out online at INDUSTRIAL MOTORING 1-877-724-5538 WHEELS, TIRES WORLDWIDE SHIPPING
and to a CumminsForum member: SH0RTYS463
HID - Xenon Lighting - RBP Diesel Performance - Gale Banks Diesel Power
BFxenon.com - Forum members receive 15% off with Coupon Code: Forum
www.facebook.com/bfxenon
BFxenon.com is offline   Reply With Quote
The Following User Says Thank You to BFxenon.com For This Useful Post:
BBRam (10-30-2009)
