#13 (permalink) | |
86 C/20 w/94 12v 420k miles http://www.cumminsforum.com/forum/cu...chevy-2wd.html 92 W250 beater - 93 Chevy HD wrecker with a 94 12v/5sp |
#15 (permalink) |
i ran my bd twins w the stock manifold turned upside down per the instructions?until i was able to buy a 3 piece.worked just fine and will smack my 60lb gauge in a hurry w ddp3s and 191s
98 12v,18* timing,191dv's,ddp3's,3850 southbend dd clutch,bd towing twins,no plate,3 pc man.,lightly ported head,o-ringed and studded,60 lb valve springs,4k gsk,and a cam that remains a mystery Last edited by bootlegger : 08-05-2009 at 02:04 AM. |
#17 (permalink) |
![]() i didnt want to pull my engine out to take the oil pan off and drill a hole like so i took an air hammer with a strait punch and punched a hole in the side of the pan and welded on a piece of the stock turbo drain tube on and used the piece of rubber hose included in the kit.
#18 (permalink) |
![]() Join Date: Oct 2008
my boss(cody spencer) former bully dog vp, was the one that drove the truck on pinks. that trucks badazz
NEW BUILD UP.... 97 6.0L Cummings 215 Pump FUEL- 100 Plate FF, 5x14s, 4gsk, 18* AIR- Volant CAI, 64/71/14, Porting, 4in STR8 Goodies- Studs, O-Rings, Guages, 13" Valair K/C Clutch, Black 7" Mitre |
#19 (permalink) | |
How did you weld on top of the drain tube... Since there is the oil pan rail I have done something similar once before and never got it to completly stop leaking through the welding... |
#20 (permalink) |
So what about these head studs? If I were to run the same twin set up, whould that mean I need head studs? What exactly do they do?? Thnaks
Custom drive shaft, Crome Dif covers, Sun Coast Tranny, New VP44, Air Dog 150, Quadzilla Adrenilne/Pulse, BHAF, 100hp Schield Injectors, Wheels and tires, 6'' full crome exhaust. |
#21 (permalink) | |
Sales Rep For BD Power
![]() Join Date: Jun 2006
Caleb... I have not seen that angle of the drain tube yet, the drain tube is very kincked, that is very likely the caues of your leak!
03 Dodge Ram 2500 "Reg Cab" Fuel: BD X-Tuner - BD X-Power - Max Flow Lift Pump Air: BD Super-B Turbo - BD Intercooler - Dual X-Hale Exhaust - BD Exhaust Manifold - BD X-Power Intake Elbow - Ice Box Air Intake Power Train: BD Transmission - BD Low Stall Convertor |
| The Following User Says Thank You to dave@BD Power For This Useful Post: | mattyDC (03-05-2010) |
#22 (permalink) | |
all our twins turbo kits are wastegated at 40-45PSI so you do not blow a head gasket, if you want to adjust the wastegate past that you should do head studs. IMO if you have, or plan to have the the jam to run R700's or R850's BD Twin Kits you should already be head-studded.
#23 (permalink) |
its not kinked. it just needs a piece of curved hose, but since i got shipped the 24v turbo kit that's all I had to work with at the time
#24 (permalink) | |
For what its worth, lets get a better hose on there and see if the leak goes away.
