Not happy......had to have it towed back to the trans shop
There was only like 2-3,000 miles on the trans, since the flexplate was installed.....
I could maybe understand this happening under WOT, but not with just trying to start the truck with a brand new "heavy duty" expensive BD Flexplate
04 QC/LB, 4WD, 305/555 HO CTD, 6" Lift, 37x13.50 Toyo Open Country MT on 20x10 BMF SOTA 8, MBRP 5", GDP Power-Flo, GDP Air Boss, GDP Grid Delete, IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special, SMARTY SR POD, ARP Head Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Edge CTS Monitor, Built 48RE Trans
Sorry to hear that D45, have you started a claim department yet, these plates are rating for big torque, obviously a flaw if it spun on start up. Should be warranty but still bad news with the tow bill and pain in the aZZ though, let me know if there is anything I can do to help out
I am highly contemplating NOT putting the BD flexplate back in, when and if it gets warrantied.....I am going to call BD this morning and see what happens
I just want to trust my truck, and this is a huge failure.....I will gets some pics posted of the flexplate ASAP
I wonder is a solid one piece unit would be better, like one from ATS
I can relate to not having confidence in the Flex Plates after that... BD has a lot of Flex Plates out there and this is definitely a first, Goerend Transmissions buys hundreds of these from BD as well and has never had a single failure that I know of. I will be interested to see what R&D's report on the plate is.
Like I said before, let me know what I can do to help, I have already send an e-mail to claims on your behalf.
The trans is out and the shop owner said this is the second BD plate he has seen do this, the other was in November
I have my RMA number with BD, and I just bought a new BD plate from Summit Racing and had it over night shipped to the trans shop
I have to send back the damaged plate and the new invoice......and BD will review the info and reimburse me
Will they help, at all, covering the $450 labor fee?
I can understand your situation, keep working with the man you were dealing with in claims, he is a reasonable man. If it is a product defect which seems like it is, I believe it is policy to cover labor, I am not sure what the rate is or what the actual policy is but will freshen up on it after I post.
Dave,
Do you know if the outer ring with the teeth is just press fitted onto the plate or is is supposed to be fully welded?
Thanks for all the help and info
I ordered a new flexplate from Summit Racing, and had it overnight shipped directly to the trans shop
The truck is back running and doing alot better
According the BD, the flexplate tooth ring is press fit onto the actual plate....and welded
The damaged/broken flexplate that was taken out of my trans HAD NO WELDS.......ANYWHERE!
The new flexplate has a serial number of 001855
The old flexplate has a serial number of 000443
Also, when the flexplate failed, it also chewed up the bendix gears/teeth on my starter......I had to pay a local starter rebuild shop $50 to install a new gear assembly.
At 73,000 miles, the inside of the starter looked brand new.....according to the rebuild shop
I am going to send BD the broken flexplate, my invoice for the labor, invoice for the starter, and the invoice from Summit for the new flexplate.....this should have never happened
$489.20 New BD Flexplate
$450 Labor Fee
$50 Tow Fee
$50 Starter Gear
Does BD have a quality control inspection department??????
