Gale Banks Question and Answer - Dodge Cummins Diesel Forum
post #1 of 94 (permalink) Old 11-12-2013, 10:47 AM Thread Starter
Administrator
Administrator's Avatar
Hi everyone,
Welcome to our First ever question and answer with Diesel Engineer Gale Banks!
This question thread will be open till the 22nd of November. Upon the close of the thread Gale will be logging onto the site and will only be answering select questions. So make sure you are asking some good questions!
Please use this thread to submit any questions that you would like to see Gale answer.
So please ask away and enjoy.
If you are new to Cumminsforum, Don't forget to register to participate!
Cumminsforum.com Admin
Autoguide.com
Administrator is online now
post #2 of 94 (permalink) Old 11-12-2013, 11:45 AM
ghostman's Avatar
iTrader Score: 6 reviews
What are you plans for NHRDA 2014 and your future in the diesel industry?
Two second gens with lots of mods and a 3rd gen just getting started
ghostman is online now
The Following 6 Users Say Thank You to ghostman For This Useful Post:
blackcoal (11-21-2013), chrisd91 (11-12-2013), hordos (03-08-2014), oldestof11 (11-14-2013), sawdustmaker (11-12-2013), w6pea (01-08-2015)
post #3 of 94 (permalink) Old 11-12-2013, 11:50 AM
bigred450's Avatar
Are the challenges of the EPA making it cost prohibitive to develop new products?
sent from a van down by the river
2012 Mega Laramie 4X4 DRW 3.73 auto stock tires MM street
OD software AMP Powerstep and Bedstep Roll N Lock tonneau
bigred450 is offline
The Following 2 Users Say Thank You to bigred450 For This Useful Post:
Fei8Lo (08-12-2014), Ramcummins5.9 (11-12-2013)
post #4 of 94 (permalink) Old 11-12-2013, 12:10 PM
World Champs!!!
MoparProud's Avatar
Any plans for turbo or supercharger kits? I believe it was Xtreme 4x4 that did an install on a red Dodge, back in 05 probably, that had a VGT turbo, what happened to that project?
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
The Following 7 Users Say Thank You to MoparProud For This Useful Post:
Clinton (02-22-2014), Fei8Lo (08-12-2014), Gregg (11-13-2013), nbk9nbk (11-12-2013), osiris (11-17-2013), Ramcummins5.9 (11-12-2013), sawdustmaker (11-12-2013)
post #5 of 94 (permalink) Old 11-12-2013, 03:25 PM
What is the reason the speed of diesel combustion is so much slower than gasoline, it is obvious to me that if we could speed up diesel engines, move the torque curve further up the rpm range, we would generate much more power. Is it as simple as flame front propagation speed or is there something else I am missing; possibly being forced to inject the fuel later in the compression stroke? I know the move to CRD injection moved the peak torque up ~500rpm but is that the limit of combustion speed?
Also what are the intake air temperatures vs. ambient of you intake system with NO scoop for the LB7?
engfuel is offline
The Following User Says Thank You to engfuel For This Useful Post:
murraykd (04-15-2015)
post #6 of 94 (permalink) Old 11-12-2013, 04:12 PM
sawdustmaker's Avatar
How much difference is there between running 50/50 Water/meth and running 100% water?
Will straight water do anything besides lower egts?
Yes i can reach the beer fridge from here
sawdustmaker is offline
post #7 of 94 (permalink) Old 11-12-2013, 04:22 PM
Western WA President
jigabop's Avatar
Any plans for an affordable and reliable propane injection system for 2nd gen and later 24v engines?
with the cost of fuel these days and propane generally being a far cheaper fuel, the cost-vs-mpg benefits of injecting propane to increase fuel mileage in most cases offsets the costs of the injected propane saving the end user some money on fuel and in some cases documented on this forum users have had gains of up to 7mpg using propane injection and the savings in diesel fuel more than paid for the propane used + extra in pocket savings.
We have been seeing fewer and fewer offerings for propane injection leaving the market pretty much wide open.
Personally if I had a easy to install kit that ran itself either mechanically or electronically to inject just enough propane for a mileage gain but not enough to cause excess egts or engine knock that was affordable and featured a tank mount between the bed and the frame, or between the frame rails, I would love to run it!
if I could get my 15mpg rig into the 20mpg range I would be jumping up in down happy! but I'm not about to spend $1000 for a kit...if it isn't affordable then the kit will never pay for itself in savings. $500 I could swing, upwards of that no way...
00 24v powered by the high performance "53" block and "Unicorn Injectors" 576hp/1285tq 8/10/2013
2004 Jetta TDI 5spd Malone S1 + dyn EGR/idle tune
Originally Posted by DieselDon16 View Post
my truck is literally full of Panties already...
Originally Posted by 'strokeThis_'07 View Post
I'll admit, I was sitting here giggling like a little girl
jigabop is offline
The Following User Says Thank You to jigabop For This Useful Post:
COMP461 (11-13-2013)
post #8 of 94 (permalink) Old 11-12-2013, 06:57 PM
Water/Methanol injection? Tell me more.
2012 2500 Crew, 6.7 auto, Mineral Gray, Carli 2.5 Pin top, high clearance arms, 35" Toyo RT
reynard101 is offline
post #9 of 94 (permalink) Old 11-12-2013, 09:22 PM
Indeed.....
3500/6 is offline
post #10 of 94 (permalink) Old 11-12-2013, 09:53 PM
I agree. I would like to know the science behind water methanol injection. Why does it work? Does it have any long term issues? I know that automotive manufacturers have toyed with this in the past. If it is this good why are they not utilizing this technology?
06 3500 cclb 4x4 drw. 5" pipe, juice w/ attitude, 100 hp nozzles, 48re.
98 24v 3500 ext cab 4x4 drw. 4" pipe, smarty, hrvp, 6 x 16, NV 5600.
95 F350 2wd drw 7.3l. 4" pipe, edge, SD conversion, afe cold air.
98blackthunder is offline
post #11 of 94 (permalink) Old 11-12-2013, 10:18 PM
If you are planning on entering the market with a water meth injection system will it have 2 modes, similar to Snow Injection's MPG and TOW modes? Will there be a multi stage system that ramps up to keep EGTs below a user selectable level?
'14 Mega 4x4 2500 Laramie Maximum Steel RamBox
APM Steps
Jackrabit sliding bed cover
B&W Companion Hitch used with Sidewinder pin box.
sconnors11 is offline
post #12 of 94 (permalink) Old 11-13-2013, 11:56 AM
CPSimpson's Avatar
So you call out Scheid, Hypermax, and Wade Moody, but you call them out to the track that is in your back yard and the farthest from all of them. Why not meet somewhere in the middle? I think it is great that you are going to race this year, but why not come out and race the whole NHRDA circuit like a lot of the other teams out there?
CPSimpson is offline
The Following 46 Users Say Thank You to CPSimpson For This Useful Post:
1stgenfloyd (11-18-2013), 24vriviera (11-14-2013), 90dodge (11-13-2013), 98-24vcummins (11-13-2013), bigmurph68 (11-15-2013), Blackcloud556 (11-14-2013), blown84 (11-13-2013), BOOST (11-22-2013), BossHossMT (02-17-2014), chrisd91 (11-13-2013), Connor Trahan (11-21-2013), Diesel_ram_man (11-13-2013), dixon700 (11-16-2013), DodgeMech (11-14-2013), EasternAggie (11-13-2013), farmboy458 (11-17-2013), feelmecummin (11-13-2013), funinmud (12-04-2013), ghostman (11-13-2013), gotdiesel04 (11-21-2013), JOESHTRDDSL (11-13-2013), jordylee18 (11-13-2013), j_cyrus (11-14-2013), ktmracer21 (11-13-2013), madmikeismad (11-13-2013), malibu795 (11-13-2013), MDowns (11-13-2013), MegaB (11-20-2013), Michael (11-13-2013), mulisha (11-14-2013), NC Firefighter (11-20-2013), oakley_xc (11-15-2013), oldestof11 (11-14-2013), Olstinker (11-17-2013), Purn1973 (11-13-2013), Rlkend (11-18-2013), roughneck0913 (11-13-2013), sawdustmaker (11-13-2013), Schrowang Farms (11-14-2013), spooled05 (11-13-2013), suıɯɯnɔ (11-22-2013), thechoochlyman (11-15-2013), treetrimmer82 (11-15-2013), TURBOLVR (11-28-2013), vtxcummins (12-03-2013), Woosley (11-14-2013)
