Go Back   Dodge Cummins Diesel Forum > General Forums > Auto Body
Old 10-04-2008, 02:23 PM   #1 (permalink)
Putting the interior door panel back on
I have a 98 12v that needed the stock speaker replaced. I got the inside door panel off fine. I am new to Dodges and am not sure how to put it back on. Do you have to replace the plastic tabs? Do you need a special tool?
I have searched the forum for several hours and haven't found anything. Can someone please help.
true1911 is offline   Reply With Quote
Old 10-04-2008, 03:24 PM   #2 (permalink)
If the tabs (also known as christmas trees) are in good shape, just put them into the slots in the door panel and push them into the holes in the door. Only special tool I have used is to take the door panel off and minimizing damage to the christmas trees and the door panel.
2000 Dodge RAM 2500, 5.9 Cummins, 4x4, 5-Speed manual transmission. Silverline 4" exhaust, Juice with Attitude,
Airdog 100, K&N air filter.
Old_Sparky is offline   Reply With Quote
Old 10-04-2008, 03:40 PM   #3 (permalink)
Thanks. Thats what I needed.
Old 10-04-2008, 04:14 PM   #4 (permalink)
get vert's Avatar
Line the Christmas trees back up in the holes and go around and hit the door panel with ur fist
99 Dodge quad cab lb, 24v, afe intake, edge attitude programmer. 4" mbrp dual pipes, 12" lift, 40" tires.
get vert is offline   Reply With Quote
Old 10-06-2008, 10:07 PM   #5 (permalink)
I'll bump this and ask..
well I have a 1st gen and I can't figure out how to get the interior door handle on/off easily. The bolt is behind the door panel which is held too close to the door itself to be able to reach it. I know there must be a trick but I've taken every screw I can find out.
New owner of a 1989 D250 5.9L Cummins. Auto, Everything stock so far.
AKturbo is offline   Reply With Quote
Old 10-06-2008, 10:15 PM   #6 (permalink)
1BadOilBurnerN-Lv's Avatar
hell on my 74 i hold the latch into the open position with a screw driver then just use a lil wrench and take the bolt out . Its the exact same as ur 89
2000 2500 sport extended cab short box. 5 inch straight piped exhaust , silencer ring M.I.A. , B.H.A.F. 354 gears , 6 inch long arm rcd lift and 37's Superchips micromax tunner
1BadOilBurnerN-Lv is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
