dually fender repair
can i use fiber glass to fix the craks and broken pieces on a 2nd gen dually fender?
97 3500 12v 4x4 4.10's 10 plate leveling kit, 315/75/16 7" miters, SBC con FE R.I.P. 97 2500 12v CTD, 4X4, NV5600, 4.10's, SBC DD,HX40/S400 Twins, 5'' stacks,Custom ground 100 plate, Laser cut DV's, 3400 gsk washer mod, Kdp RIP 6/21/06,$:
#2 (permalink) |
nobody? is there anything i can use?
#4 (permalink) |
I have a couple of the pieces that need to go back on but they are on the back of the fender where it bolts on, but on the front side of one of the its broke but everything is still there. I would like to fix these the most.
#5 (permalink) |
Super Moderator
go to an autobody store and use a product called fusor #100. 3m, kent ,SEM also make the same product, it will work a lot better than fiberglass.
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin 2 stroke. |
#6 (permalink) |
when i made my fender flares i used my old ones as a template and pattern, but if you use fiberglass, which will work very nicely, grind out some of the old material and lay down your resin then put on your glass and work it in, go over the old material and sand off later to the desired contour. if you need some filler, filler epoxy 101 or 300 i think by west marine. its a fiber filler for the resin. ill look up the number later on. and if you need to bond a small crack use MarineTex Epoxy.
98.5 3500-22.5" Rims, 2" lvl kit, LED,EdgeJuice/Att,4dwnpipe,ATS 3 Pice Manifold, ATS PerformanceTRans,ATS T/C,custom fenders,ATS CoPilot,6" Bull Horns,Guages FASS Fuel Pump 95Gal,Hadley Air Horns, BHAF, Guages, jammer3, Lnd Visor,Dipricol Gauges |
#7 (permalink) |
We use Kent Ind. 2 part epoxy adhesives with a mesh backing over the repair area to add a little strength.
'01 QC dually 4x4 -silver- Banks power elbow 4" exhaust with 5" stacks 80hp BD injectors Edge EZ box Moded air box Boost fooler Pyro and Boost gauges |
