Go Back   Dodge Cummins Diesel Forum > General Forums > Auto Body
Old 09-09-2008, 08:44 PM   #1 (permalink)
jayhaitch's Avatar
help with rust
My doors are rusting on the inside where the folded seam is, on the bottom of each door. Nothing showing through on the outside yet. Rock chips and bubbled rust spots are common here, so I know what to do with them, but how about this area?
Would going at it with steel wool or a Dremel tool to get off surface rust, then DTM rust primer (Tremclad, Rustoleum) then touch up with body color be of use? It doesn't have to be pretty, just effective at preventing rust perforation and me needing new doors.
Anybody have any suggestions?
98.5 24V, 5sp QC SB 4x4, electric blue, 3.55, AutoMeter pyro/boost/FP, DSS, Diamond Eye 4" turbo back, Power Puck, 2-stroke oil, Challenger tool chest
jayhaitch is offline   Reply With Quote
Old 09-09-2008, 08:51 PM   #2 (permalink)
agoldxj's Avatar
look up por-15, that is your best bet in stopping it.
06 flame red ctd thunder road slt sbqc auto 4x4, 4.5" lift, 35" toyo mts on black xd hoss', bd steering box stabilizer, afe stage 2 pro dry, cat/muffler delete with 6" tip, debadged , door strips mia, night runner head lights, recon smoked cab and 3rd brake lights...
agoldxj is offline   Reply With Quote
Old 09-09-2008, 08:57 PM   #3 (permalink)
5.9 guy's Avatar
Also try to spray the seem out everytime you wash it and underneath the cab to anything will help.
02 2500 extended cab edge comp/drag box, K&N intake, 4 in MBRP exhaust, built trans, billet converter,HTS valvebody, autometer guages (trans temp, boost, egt, fuel press) bd frame mount lift pump, silencer ring moved out , lock-up switch
5.9 guy is offline   Reply With Quote
Old 09-09-2008, 08:58 PM   #4 (permalink)
mallen's Avatar
I heard rust bullet is the best product in stopping it. I'm tackling my door seams with it as soon as it arrives in the mail and will make a post to how it goes.
1998 2500 12 valve,5spd., 2wd, tst #12, straight pipe, michelin ltx, line x liner, ready to work, ready to put more mod's on
mallen is offline   Reply With Quote
Old 09-09-2008, 09:05 PM   #5 (permalink)
cummin not strokin's Avatar
mines doin it to i tryed grinding it out and it started to take chunks out or the lip
2001 24 v with power puck and 5in. stacks silnecer ring mia RIP custom tailgate " id rather be cummin then strokin" mystery switch. soon more to come!!!
cummin not strokin is offline   Reply With Quote
Old 09-10-2008, 02:23 AM   #6 (permalink)
NOBULL's Avatar
sand blast, rust mort, then finish and paint. However rust on the outside means rust on the inside and it will come back. Dodges are famous for there...well they all are i guess. Can't wait to see what the new ones will be like with rubber trim and seals on the bottom. I always peel back the rubber and pressure wash because you should see the crap that always gets under there.
2008 Dodge 2500 Quad Cab Sport 6.7L 6speed automatic, 4X4. 6inch pro comp lift, dual steering stabilizer, 37X12.5X17 inch pro comp extreme MT tires, 17inch American Racing Atlas Rims, bushwacker flares, Custom "Real Fire" paint over electric blue
NOBULL is offline   Reply With Quote
Old 09-10-2008, 05:49 AM   #7 (permalink)
ya thats true i just took my strips off tired of crap getting caught in there
Old 09-10-2008, 06:01 PM   #8 (permalink)
jayhaitch's Avatar
I forgot about POR-15. I haven't used it but it's popular on many other vehicle forums I've read. Thanks.
Old 09-28-2008, 09:53 AM   #9 (permalink)
Biodiesel Cult Member
ak_cowboy's Avatar
I have used por 15 and its works great. I have used it as a sealer on bare panels before filler and no rust flashing. just don't use it as a top coat. It is UV sensative.
2006 2500 Mega Limo 5.9 CRD running homebrew Biodiesel
Triple Dogged w/ Outlook,2 inch level kit, Silencer ring.....MIA, AFE Torque tube, Amsoil BHAF 4510
1967 Dodge Polara 500 currently getting a face lift. 383ci .030 Edlebrock 750 carb, 484 lift cam @ 272 duration = 14.5 second land yacht!
ak_cowboy is offline   Reply With Quote
Old 10-01-2008, 08:32 PM   #10 (permalink)
dieseldick's Avatar
i used permatex rust converter in a can. it converts to black oxide. you actually see it work. i top coated with rustoleum primer and rustoleum satin black. i had rust in my cab under the carpet. so bad the carpet was stuck to the cab.
1997 2500 4x4. 3" jacker, 35" nitto terrains, stock steel wheels, rear air ride. 4 inch straw. ispro guages.
dieseldick is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
