Go Back   Dodge Cummins Diesel Forum > General Forums > Auto Body
Old 01-27-2008, 05:39 PM   #1 (permalink)
jr22's Avatar
interior paint
hello, I want to redo my interior panels door panels and dashboard a new color to match the truck whats the best paint i can use ?? any tips ?? spray can or spray gun thanks, jr
2008 Dodge Ram 3500 grey with line-x rockers and box. 6.7l cummins 6spd mt 4x4 quad cab long box. 2008 arctic cat m1000 162 track orange,2006 arctic cat 500le 4x4 atv red.2005 bearcat enclosed trailer
jr22 is offline   Reply With Quote
Old 01-27-2008, 05:49 PM   #2 (permalink)
ibcummin's Avatar
As long as you scuff the surface of the panels, spray bombing should work fine with light even strokes. When you get it done, post some pics. I thought about it myself.
2005 RAM 3500 H.O4x4, QUAD CAB, LARAMIE Gone but not forgotton!
Replacement: 2008 Nissan Altima SE 3.5.
ibcummin is offline   Reply With Quote
Old 01-27-2008, 05:52 PM   #3 (permalink)
jr22's Avatar
will do:thumbsup, jr
Old 01-27-2008, 06:04 PM   #4 (permalink)
Tech Specialist
SmokinDiesel's Avatar
I am also looking to do mine this spring ... My current interior is tan ... (with the exception on driver a-pillar pod & passenger a-pillar) ...
I know I am going to get a black dash top from Geno's, Pull the tan carpet and replace with black, and do Katzkin custom leather seats & door panels ... I was also thinking of painting all of the remaining tan dash black ...
Michael Charlton - Keystone Diesel
SmokinDiesel is offline   Reply With Quote
Old 02-10-2008, 08:42 PM   #5 (permalink)
e-rok's Avatar
Look into SEM Color-Coat interior paint. I have heard good things about its durability.
I also am planning on redoing my interior black (my truck is blue and I have an ugly blue interior)
1995 3500 DRW Ext. Cab 2wd
e-rok is offline   Reply With Quote
Old 02-14-2008, 03:54 PM   #6 (permalink)
get vert's Avatar
I do this at work all the time on dashes. Use SEMS. Great product. Clean it VERY VERY WELL before to start sanding and then clean again. Armor All if the worst thing ever for paint applying. Use a heat gun and warm up the can and dash first. I also spray and swipe the heat gun in the same pass. To reduce fish eyes.
99 Dodge quad cab lb, 24v, ALL CUSTOM
get vert is offline   Reply With Quote
Old 02-14-2008, 09:50 PM   #7 (permalink)
jr22's Avatar
thanks for the replys i just got a lmc catalog and they offer some interior paint also thanks, jr
Old 02-14-2008, 09:55 PM   #8 (permalink)
Administrator
rbmchief's Avatar
sem makes an awesome product, ppg also makes an elastomeric interior paint that is available in a lot more colors, but you need a paint gun to apply it, it works as good as or better than the sem just not as user friendly.
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin stanadyne. [url]
rbmchief is offline   Reply With Quote
Old 12-26-2008, 12:52 PM   #9 (permalink)
cumminsturbo94's Avatar
so do you guys have any pics if your dashes youv done?
'94 ram 2500 12-valve, auto, soon to be silver
OHIO COAL ROLLERS
cumminsturbo94 is offline   Reply With Quote
Old 02-09-2009, 04:13 AM   #10 (permalink)
rolncol93's Avatar
i have done numerous dashes seems to me with the dodges is just to get the front window out. trust me it seems alot easier than takin the dash out. sand to how smooth you want it, spray a couple of coats of adhesion promotor sand lightly and then shoot the color that you want. lay a couple of coats and then a couple clear coats then cut and buff. depending on how much you sand it comes out like glass very nice.
93 w350 12v cc single wheel 36 12.50 military oz m/t h1 beadlocks run flats 109k on motor... 159k on truck and running gear... 4" intake 16mm hot side 4"dp 5" stack, Mostly stock RBS PERFORMANCE NO BOX NO BOTTLE, JUST BALLS AND THROTTLE
rolncol93 is offline   Reply With Quote
Old 02-09-2009, 05:24 AM   #11 (permalink)
PJ 3's Avatar
Krylon make a new product called " Fusion For Plastic " although the colors are limited. Here's the link..........Krylon: Products: Fusion for PlasticŪ
PJ 3 is offline   Reply With Quote
Old 02-10-2009, 09:43 PM   #12 (permalink)
J-Mayne's Avatar
I sprayed mine with krylon fusion and sem but they will still come off. Make sure you spray on a coat of ahesion promoter or acetone. Then clear coat it really good. Pastics are hard to stick to so i went with bedliner.
07 Quad, Leveled, 20" Motometal Skull W/ 35's , Smarty w/TNT,Edge EZ, Valair 3850 Dual, 2nd Gen intake, digital gauges, s&B W/ amsoil, Custom Dual 9" Miters, Missing Silence ring, Running lights. 542 HP 974 Ft Lbs
J-Mayne is offline   Reply With Quote
