Go Back   Dodge Cummins Diesel Forum > General Forums > Auto Body
Old 04-16-2007, 09:40 PM   #1 (permalink)
JSPulliam21's Avatar
Quad cab door latch adjustment
The inside handle on the passenger side back door does not open the latch. It seems like the linkage may not be adjusted properly. The outside handle opens the door just fine, but the inside handle needs to pull just a little farther to open the latch. Any ideas?
98.5 3500 QC LB NV4500 4x4 3.55 SRW, DiPricol gauges, BHAF, 4" Silverline, FBD 150's, Edge Comp, Valair 3800 DD, Draw Straw, 1/2" Filter to IP Line, FASS 95HPFP, 2" Leveling Kit, DSS, 35" Toyo M/T, KDP killed 403HP/899 TQ
JSPulliam21 is offline   Reply With Quote
Old 04-17-2007, 03:50 AM   #2 (permalink)
goosesgarage's Avatar
Im not sure how the linking is but on most its a metal rod that has plastic inserts that go in the holes on the latch and door handle and they may be wore out. Also the handle is plastic so mabe the hole is wore out on the inside handle. Not sure if thes helps but just a thought.
97 dodge 3500 drw nv4500 single cab western hauler with a few mods
http://www.neweradiesel.com
goosesgarage is offline   Reply With Quote
Old 04-17-2007, 10:51 AM   #3 (permalink)
That is what I figured, but how do I get to the linkage to adjust it or replace the sleeves?
Old 04-17-2007, 11:08 AM   #4 (permalink)
Illinois Chapter President
Headhunter's Avatar
first try to pull in on the door when trying to open it from the inside, I had the same problem and it was a rust build up on the assembly in the bottom & top of the door & on the truck.
I just used some PB and a wire brush and now the door opens just fine from the inside.
just a though before you buy any parts!
Illinois Cummins Crew President Illinois Chapter Forum
2007.5 Ram 3500 6X4X4, 68RFE, Fronteir EXtreme out front, T3 Dually wrap out back! Auto pilot Smarty JR on it's way~
Headhunter is offline   Reply With Quote
