Go Back   Dodge Cummins Diesel Forum > General Forums > Auto Body
Old 10-25-2009, 05:56 PM   #1 (permalink)
06+ grill on 30-05 bumper
Like the title says, anyone with pics of an 06+ grill on a 03-05 bumper? how about a sport bumper?
04 3500 DRW 4dr 4x4 CTD (555) few mods.
07 Trailblazer SS, LS2 400hp, magnaflow exhaust, tinted windows, full of Amsoil, leather, navigation, and every other possible option.
MPD106 is offline   Reply With Quote
Old 10-25-2009, 08:07 PM   #2 (permalink)
sniper's Avatar
I'm not quite sure it will work with the dips under the headlights, you will probably need to add the 06+ top peice on your bumper!
2005 CC SB G56
Smarty-SB3600 DD-FBD 5"-Araid Intake-Isspro Gauges
Centerlines-Mickey Thomson ATZ-Clarion Audio
sniper is offline   Reply With Quote
Old 10-26-2009, 09:07 PM   #3 (permalink)
I am pretty sure it will work, ive seen a 03-05 truck with an 06+ bumper before.
Old 10-28-2009, 02:10 AM   #4 (permalink)
If it does work, which I don't think it does, I don't think it would look right.
07' 5.9
Lorenz, 35's
37's soon
pitrack is offline   Reply With Quote
Old 10-28-2009, 08:19 PM   #5 (permalink)
MMStar923's Avatar
it fits. you need different mounting hardware, and it doesnt look half bad actually....i mean in the corners its kinda off, but ive seen it done and looks good
MMStar923 is offline   Reply With Quote
Old 10-28-2009, 09:16 PM   #6 (permalink)
MikeyB's Avatar
Also seen one. Looks a little different with the triangle shaped openings between the grill and the bumper cover. Doesn't look bad.
MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2
MikeyB is offline   Reply With Quote
Old 11-05-2009, 01:33 PM   #7 (permalink)
you should just do the complete 06 front end replacement..then the grille would be a perfect fit. lol just my .02
1997 3500 DRW, 4x4, NV4500, 4.10 gears, ext cab, flatbed, #6 plate, afc slid forward, starwheel cranked, K&N CAI, on board air, wastegate plugged, straight piped to 5 inch turnout stacks, flip out tow mirrors, PSC power steering pump and fluid cooler
Jameson Bearden is offline   Reply With Quote
Old 11-15-2009, 03:02 PM   #8 (permalink)
Wears a tinfoil hat
Ten_Bucks's Avatar
I know someone(who is also a member on here) who has an '03 3500 SRW with an '08 Laramie grille and front bumper on it. The truck looks really good and is unique because you don't see that mod too often.
Scott
RTCTTFMF!
http://www.myspace.com/tenbucks76
Ten_Bucks is online now   Reply With Quote
Old 11-17-2009, 10:45 AM   #9 (permalink)
MikeyB's Avatar
Scott
How did he do it with the stock headlights? Did he drop the bumper down a little to clear the bottom of the headlights?
MikeyB
Old 11-17-2009, 04:35 PM   #10 (permalink)
Wears a tinfoil hat
Ten_Bucks's Avatar
MikeyB
Bumper was dropped down a little bit. When he first told me about his plan to do this mod, I was worried a little bit about that gap in between the top of the bumper and the bottom of the headlights. But after seeing the truck post-mod, it isn't as bad as I thought it would be. The truck turned out great.
Scott
RTCTTFMF!
Old 11-17-2009, 05:11 PM   #11 (permalink)
fmff21's Avatar
Well i was wanting to put the sterling grill from the 4500 on mine, I know it will fit a 06
2004, 2500, 4x4, auto,3.73, banks ram air with scoop, Silencer Ring "MIA", 5" turbo back,
fmff21 is offline   Reply With Quote
Old 11-17-2009, 05:11 PM   #12 (permalink)
fmff21's Avatar
would that fit?
