Wanna paint my window vent visors - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 09-05-2009, 12:34 AM Thread Starter
Remuda Rancher's Avatar
I have seen vent visors painted to match the trucks. What I was wondering is: can I use the duplicolor aresol can of bright white from Auto Zone or O'Riley's to come close to matching the color of my 07white truck? Has anybody used the duplicolor dodge/chrysler bright white for any matching purposes and have ya had satisfactory results? Thanks for any help here.
2007, 3500 Laramie, Mega Cab, 4x4, DRW, 6 speed auto, 5.9L Cummins......S/B air filter w/ Ram Air Scoop, Frontier Bulldog replacement front bumper, Linex bed lining
Remuda Rancher is offline
post #2 of 7 (permalink) Old 09-07-2009, 07:06 PM
NC4WD's Avatar
You will need a plastics adhesion promoter. The rattle can white might be close, I would just have a shop do them.
Y2K | NV4500 | NP241DHD | BHAF w/ prefilter | BD Wastegate | Edge Juice With CS Monitor | AirDog II | Dana 80 | Valair Clutch 500/1000 | NC4WD Flat Bed | GM Wheel Cylinders | 3rd Gen Wheels | 3rd Gen Front Brakes | Super HD Track Bar | Skyjacker Rear Springs | NC4WD Pre-Runner Bumper | Bilstein 5100's Front / 7100's Rear | 6" Grand Rock Stack | 35" KM2's | Amsoil Bypass Filter | North Country Rock Sliders | Cummins Coolant Filter | Lots of Ballistic Fabrication Parts | T-Style HD Tie Rod| Heavy 2 Stroke Diet | Updated 5th Gear Nut | Puke Bottle Delete | DSS Steering Stabilizer | Heavy Duty Lower Control Arms
NC4WD is offline
post #3 of 7 (permalink) Old 09-10-2009, 10:27 PM
take the paint code to a automotive paint shop have them mix it and put it in to a paint can get some adhesion promoter and some rattle can clear and paint away wash with hot soapy water
mopi is offline
post #4 of 7 (permalink) Old 02-06-2010, 08:49 PM
I got mine painted to match the truck. A body shop did it while i was getting some work done. They said they put some other stuff in the paint because at hiway speeds they can flex and may crack the paint. I love the way it looks. Nice and clean.
07, 4x4, SLT, Mega Cab, 5.9, 3.73, auto 4 spd, White, Recon smoked cab lights, Pattonfab light bar, Viair on board air, Isspro egt, boost trans, Stock
deer slayer is offline
post #5 of 7 (permalink) Old 02-24-2010, 03:27 PM
chris.roan's Avatar
I had mine too. Goo to realtruck.com and order the window visors from them that are an exact paint match. Just got mine last week and put them on and dam do they look good!
2010 Laramie Mega, 1998.5 Heavy Hauler,1993 W350,1993 D350.
chris.roan is offline
post #6 of 7 (permalink) Old 02-24-2010, 04:53 PM
zenkstow's Avatar
if you dont want to go to the cost of having a paint shop do this for you here is what you do.
if you buy the duplicolor paint.
spray a test panel - use piece of scrap or something you dont care about, when its dried
put it next to your truck see if its a match.
Clean vent good with soap and water.
Use a scotchbrite pad (red) scuff vent
clean with a prep solvent ( nothing to agressive as it will melt the plastic
spray a DUST coat of self etching primer. you do not need to go heavy with this
self etch primer will allow paint to adhere to vent. and a dust coat is
you need
Spray your paint - 1st coat i would spray light (i call this a tack coat) then go back with
two medium coats
Hope this helps
zenkstow is offline
post #7 of 7 (permalink) Old 02-28-2010, 06:10 PM
I would use plastic adhesion promoter and a flex agent,you can get the adhesion promoter in a spray bomb at any auto paint supply the flex agent you usually add to your paint or I think you can get flex bumper paint that can cover all the bases.
99 CTD, Quad cab, RWD, dually, nv4500, with 1,000,000 km. The motor has never been touched.
06 F350 future fummins
12VFan is offline
