6.7L Heater delete and performance airhorn install - Dodge Cummins Diesel Forum
Articles - Engine, Other Everything else relating to engines
post #1 of 9 (permalink) Old 08-01-2011, 12:34 AM Thread Starter
Tech support junkie
powerstroke8994's Avatar
Well we had another nice day today so i got out this am and got some work done. Got to install these 2 parts. I also had a boost tube i was gonna install but turns out it was for a 2007 to 2009. Ill have more down the road on that one. But heres my install pics and stuff. Hopefully this will help someone out. I really didnt take as many pics as i wanted cause i wasin abit of a hurry.
First remove your dipstick bracket
Now remove the intake horn
Now take this nut off here and theres also one on the other side take it off too.
Take the CAC clamp off and pull the hose off.
Now take all your fuel lines off including the FPRV line *SAVE THE WASHER FOR THIS
Now remove the bolts out the rail and the plate for the heater and unplug the FRPsensor
Now clean off the bolts thread sealer so you can install new stuff.
Kinda ran outta pics but anyways swap over the MAT sensor to the delete plate. The map sensor over to the new air horn. Reasse in reverse order. Be careful not to drop anything into the head and clean your surfaces. Also DO NOT TRY AND CRACK THE LINES TO BLEED THE SYSTEM. If you do this it can spray you and itll cut you and give you wonderful blood poisoning. Seen a old timer do this on a CR system once thinking it was like the old mechanicals. So once you get it all back together and youll see theres less clamp holding wires on. Just zip tie em up. So now youll wanna crank it over and have it start. You can crack it for a while. Some guys wont crank for more than 10 secs but cranking it for 40sec or so wont hurt it.
Youll also need to install the dipstick brack on the breather
2014_F-250_Platinum
SOLD-2010_48re
SOLD_2013 MEGA_g56_laramie_Loaded
CUMMINS & N SERIES
Powering Americas Future
powerstroke8994 is offline
The Following 2 Users Say Thank You to powerstroke8994 For This Useful Post:
2012 RAM 3500 (12-14-2011), Mudman1 (02-03-2013)
post #2 of 9 (permalink) Old 12-01-2011, 11:45 PM
THE OX
devinoxford's Avatar
iTrader Score: 7 reviews
Did you do a Grid heater relocate? If not how does it start in the cold(could you post a video of cold start)? Want to do it to mine but I don't know how hard it will start without it?
DD: 2007.5 Dodge RAM 2500 QC/SB,2WD,6.7L, 3.73 gears switch to 3:42, DPF and EGR + Cooler Delete, EFI Live. 119k miles on 04/08/2014. Stock trans and head gasket(no studs). deleted since 40k miles run the efi on race all the time, ran h&s175hd and smarty level 9 before efi.
When I get time to restore: 1969 Chevrolet Custom Camper/20 350 with turbo 400 trans 68,000 original miles (was my great-grandfathers)
devinoxford is offline
post #3 of 9 (permalink) Old 12-14-2011, 09:59 AM
Glad to Be Here
2012 RAM 3500's Avatar
I can't see the pics, are they still there or is my browser goofed?
2012 RAM 3500 is offline
post #4 of 9 (permalink) Old 12-21-2011, 09:12 AM
Glad to Be Here
bump-----------
post #5 of 9 (permalink) Old 12-26-2011, 11:29 AM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
Browser must be goofed, the pics are still there.
Yes he did use the grid heater relocation kit. You can see the studs and grid heater mounting bolts in the throttle valve.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #6 of 9 (permalink) Old 04-24-2012, 06:23 PM
Can I ask what is the clear nylon tubing being used for.
Thanks,
Russell
RSRains is offline
post #7 of 9 (permalink) Old 04-24-2012, 06:34 PM
Mechanical boost gauge.
post #8 of 9 (permalink) Old 04-24-2012, 08:19 PM
OK, I see where you had it hooked to the front inner bolt on the OEM air horn and now to the back of the Shibby Horn.
RSRains is offline
The Following User Says Thank You to RSRains For This Useful Post:
waste_people (04-12-2013)
post #9 of 9 (permalink) Old 04-11-2015, 11:13 PM
How do you release the fuel pressure before you remove the lines?
What are the torque values on the intake bolts?
Richx76 is offline
