Edge EZ Install on 04.5-07 - Dodge Cummins Diesel Forum
Articles - Engine, Other Everything else relating to engines
post #1 of 1 (permalink) Old 03-03-2011, 09:35 AM Thread Starter
Hide your cats!
mstoaks's Avatar
So, you got yourself a Edge EZ and are pumped to feel the power - you want to install it now! This write up will explain how to install a Edge EZ on a 2004.5 through 2007 Dodge Cummins.
Step 1. Find the Manifold Absolute Pressure (MAP) and fuel rail pressure sensors. This is the MAP sensor.
This is the fuel rail pressure sensor.
Step 2. In any order unplug both sensors. They are both ran through the same wire loom.
Step 3. Find the matching plug end on the EZ and plug it into the factory plugs you just unplugged.
Step 4. Find a place to mount the EZ, i just tucked mine in next to the battery.
Step 5. Find a good place inside the cab to mount the 3 position switch. Mine is kind'a hidden next to the steering column.
Step 6. Run switch wire through fire wall and plug in to matching plug end. Button things back up and go have fun with you new found power!
2005 white auto, thanks to stoakenstine creations, 23 Diesel,smarty so6 Ats 5-star, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 547hp 1078ft.lbs
mstoaks is offline
The Following User Says Thank You to mstoaks For This Useful Post:
WVcummer (03-14-2011)
