New AMSOIL Diesel Additive for ULSD - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > AMSOIL Twin Port Sales
AMSOIL Twin Port Sales Visit them at Twin Port Sales.com or call at: 218-349-4133
Old 08-30-2006, 10:34 PM   #1 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
Thumbs up New AMSOIL Diesel Additive for ULSD
This all new Diesel Concentrate replaces the old AMSOIL Diesel Fuel Additives.
Improves combustion, fuel efficiency, cold-weather starting, power and performance. Cleans injectors, fuel screens, pumps and filters. Designed for use in cars and light duty trucks. 16-oz. bottle treats up to 80 gallons of fuel.
Package sizes include:
16-oz. Bottle
16-oz. Bottles (case of 12)
5-Gallon Pail
55-Gallon Drum
One 16 ounce bottle (treats 80 gallons) costs $6.65 normally, but Preferred Customers can get it for $5.00 each.
Please PM me if you'd like to become a Preferred Customer, or follow the link in my signature.
Diesel fuel, like diesel engines, is changing to meet emission and other environmental requirements. The Environmental Protection Agency (EPA) has introduced major changes in diesel fuel for 2007, including Ultra Low Sulfur Diesel fuel (ULSD), bringing the sulfur content to 15 ppm, a staggering drop from the current requirement of 500 ppm. Lower sulfur means lower lubricity, the property that controls wear in the fuel injectors and fuel pump.
New emission regulations have brought on engine modifications such as exhaust gas recirculation (EGR), causing rapid TBN depletion due to acid formation and higher levels of soot loading in the oil. Higher soot and particulate content has resulted in the introduction of diesel particulate filters, but they clog easily, lowering engine efficiency. All of these changes mean that new diesel fuel needs quality fuel additives to keep equipment operating efficiently and prevent malfunction. AMSOIL has made some changes to its line of fuel additives. The changes reflect the new diesel fuel regulations and incorporate the latest in fuel additive technology.
AMSOIL Diesel Concentrate
AMSOIL Diesel Concentrate has been reformulated with additional lubricity properties. The new AMSOIL Diesel Concentrate (ADF) is a total system cleaner and lubricity improver for all types of diesel engines. AMSOIL Diesel Concentrate compensates for the quality variances of different fuels (including biodiesels) and the deficiencies of today’s ULSD for better engine operation.
Reduces Cylinder Wear, Retains TBN Longer
New low-emission engine models with high rates of exhaust gas recirculation have inherent lubricant challenges. These engines dump excessive amounts of soot and acids into the oil, accelerating wear on the cylinder walls. Additionally, new engine oils meeting CJ-4 requirements will have lower sulfated ash content, which controls TBN levels. The new mandate only allows enough sulfated ash content to reach a maximum TBN of eight, making TBN retention even more important. New AMSOIL Diesel Concentrate controls these issues by neutralizing acids during combustion. This minimizes acidic cylinder wear and reduces the rate of engine oil TBN depletion, maintaining engine oil quality longer for better protection.
Minimizes Soot Loading
AMSOIL Diesel Concentrate is a powerful cleaner that cleans fuel injectors and piston rings for improved combustion and better sealing. It minimizes soot generated from incomplete combustion and helps keep soot out of the crankcase. Reduced soot loading controls soot related wear and engine oil viscosity increase.
Fuel Stabilizer
Fuel degradation can cause gums, which increase deposits and the chance of filter plugging. AMSOIL Diesel Concentrate significantly improves the oxidation and thermal stability of diesel fuel. It overcompensates for ULSD fuel’s potential stability loss caused by extra processing and sulfur removal. Diesel fuel treated with AMSOIL Diesel Concentrate easily meets the requirements of the National Council of Weights and Measures (NCWM) Premium Diesel Fuel Specification for resisting diesel fuel degradation.
Improves Fuel Economy and Restores Horsepower
Diesel engines become less efficient over time. Fuel injector deposits interrupt spray patterns, causing poor fuel atomization, incomplete combustion, excessive emissions and smoke. Tests prove that AMSOIL Diesel Concentrate cleans dirty injectors, not only improving fuel economy by up to five percent, but also restoring horsepower to like new. Acceleration is improved, and with regular use, AMSOIL Diesel Concentrate continues to enhance performance by keeping injectors clean.
No-Cost Additive
High fuel prices are increasing operating costs for everyone. AMSOIL Diesel Concentrate has proven in industry standard tests to improve fuel economy in used diesel engines by up to five percent. At $3.00 per gallon for diesel fuel, even a modest three percent improvement in fuel economy equals a savings of $0.09 per gallon. With a treat rate of one oz. of AMSOIL Diesel Concentrate to five gallons of fuel, at U.S. Retail price the net treat cost of AMSOIL ADF is $0.083 per gallon, bringing the total savings to $0.007 per gallon and negating the cost of AMSOIL Diesel Concentrate altogether.
Improves Water Tolerance
AMSOIL Diesel Concentrate is an alcohol-free product that protects fuel systems against water contamination. It helps prevent fuel/water emulsions and it protects metal against rust. Water can be drained easier and fuel filters are less likely to plug, ensuring drivability.
AMSOIL Diesel Concentrate Replaces AMSOIL Diesel Modifier
AMSOIL Diesel Modifier is discontinued, and new AMSOIL Diesel Concentrate is applicable in its place. There are no longer different fuel additives for heavy- and light-duty diesel engines, simplifying applications for customers. New AMSOIL Diesel Concentrate meets and exceeds all catalytic converter requirements.
AMSOIL Diesel Cold Flow Improver
Combining AMSOIL Diesel Concentrate with a cold flow improvement property is not cost effective in the summer months, or to AMSOIL customers who live in the south. To keep costs down for customers, AMSOIL Diesel Concentrate no longer includes a cold flow improver. Instead, AMSOIL provides new AMSOIL Diesel Cold Flow Improver (DFF) for low-temperature applications below 40°F.
Diesel fuel forms wax crystals and gels in cold temperatures, plugging the fuel filter and affecting engine operation. AMSOIL Diesel Cold Flow Improver for diesel fuel is designed for use with ULSD, yet works well with conventional fuels. It functions by modifying the wax crystal formation at low temperatures to depress the pour point and improve the cold flow filtration properties. AMSOIL Diesel Cold Flow Improver lowers the cold filter plugging point by as much as 20°F and decreases the need for #1 diesel fuel that is diluted with kerosene. AMSOIL Diesel Cold Flow Improver contains jet fuel-type deicer to help prevent ice formation in fuels contaminated with water. It is recommended for use with diesel engines and is compatible with diesel exhaust particulate filters (DPFs). AMSOIL Diesel Cold Flow Improver is excellent for use with AMSOIL Diesel Concentrate and AMSOIL Cetane Boost Additive. Recommended mix ratio is one oz. of additive per five gallons of fuel.
Heating Oil Improver
AMSOIL Diesel Concentrate provides many of the same benefits in heating oil furnace applications. For this reason, Home Heating Fuel Extender (AHF) is discontinued. AMSOIL Diesel Concentrate provides fuel oil storage stability, water stability, rust protection, fuel oil filter longevity, and in certain applications its detergency properties should keep fuel oil nozzles clean for proper spray in the combustion chamber. AMSOIL Diesel Concentrate promotes trouble-free operation. AMSOIL Diesel Cold Flow Improver is recommended where fuel oil is stored outside.
Recommendations
AMSOIL Diesel Concentrate is recommended for use with all types of heavy and light-duty, on or off-road and marine diesel engines. The recommended mix ratio is one oz. of additive per five gallons of fuel. It should be used with every new tank of fuel for the best performance and protection against fuel pump wear, injector wear and injector deposits. It is compatible with all types of exhaust emission systems such as diesel particulate filters (DPFs). It is recommended that AMSOIL Diesel Concentrate be added to fuel before storage. Diesel Concentrate is excellent for use with AMSOIL Cetane Boost and AMSOIL Diesel Cold Flow Improver.
Sweeping Changes
All AMSOIL fuel additive products will be sold in 16 oz. bottles that have 22 ml. openings that fit directly into gas tanks. The bottles are natural in color with graduations on the label to ensure correct dosages. All products have a new mix ratio of one oz. of additive to five gallons of fuel (one bottle treats 80 gallons of fuel). AMSOIL Diesel Concentrate and Diesel Cold Flow Improver are now available in the new, more convenient bottle.
Proud Cummins Forum Sponsor since 2006 - SUPPORT YOUR CUMMINS FORUM SPONSORS, WE SUPPORT YOU. THANK YOU!
Specializing in AMSOIL everything
Duluth Diesel is offline   Reply With Quote
