| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
In the new Diesel Power magazine they have a 12 truck shootout. One of the events is they all drive the same loop and best mpg wins. Well this year the winner got 38 mpg. ![]() That is on a truck that dynoed at 1232 lb-ft of torque. His secret is CNG, compressed natural gas, which is injected similar to propane. To make things even better he buys CNG for .70 cents a gallon. Does anyone have any more info on how to do a CNG injection setup? Who sells a kit? With the incredible money savings this offers i really want to look into it. One factor is the availability of CNG. Obviously you can't get CNG just anywhere so that is a problem. You can buy a home setup that uses your house gas line. Some larger towns have CNG stations so that needs researching.
2008 Dodge 3500 SRW Quadcab LB 4x4 Mineral Grey, Auto, 3.73, 6.7L Cummins. Lorenz suspension. Thuren trackbar, Toyo 35 M/T. HID's. All deletes. PMT. Aeroturbine 4040XL muffler. |
#2 (permalink) |
GA Chapter Vice President
A diesel that runs CNG as it's only fuel isn't the same as a DI diesel engine. Did the truck run solely on CNG or was it just an additive?
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse BHAF, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan. Parts to come: 150hp sticks, turbo, and bigger exhaust. |
#4 (permalink) |
Super Moderator
![]() Join Date: Nov 2006
CNG system on Diesel Power Challenge truck 38mpg! - Competition Diesel.Com - Bringing The BEST Together A good thread on CompD on the topic.
Dennis 04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, TS Ramifier, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass Check out: Rig of the Month! ![]() http://www.cumminsforum.com/forum/rig-month/ |
#5 (permalink) |
It was an additive. There is a shop locally that loves to do these things.
01 ext. cab, shrt bed, 6spd w/ BD short shift kit, edge juice w/hot, bd 155 sticks, sb con fe clutch, 5 inch Diamond Eye, BD aux lift pump, Smarty, II silver 62, Haisley Machine O-ring head gasket, Arp Studs, all done by me! |
#7 (permalink) | |
UR FRIENDSHIP DUES R LATE
07.5 6.7l 2500 MegaCab 6sp Auto, 4x4 Inferno Red, Tough Country front Replacement, Browns Rear Replacement, NFab crappie 6 steps, Painted Pocket Flares, 20x10 4.56 backspacing Black Rockstars, 35" Toyo A/T's, 6" Superlift, Air Bags, 96' 2500 4wd, 47RE, Ext Cab,5" TBE,AFE Drop in, 134k ANTI- ![]() Poor People have been voting for Democrats for the last 50 years... and they are still poor. |
#9 (permalink) |
WOW thats really cool that link rufushusky gave us has the guy in the mag. so how exactly does it inject the CNG? is it similar to propane?
'94 ram 2500 12-valve, 4x4, 3.55's, 47rh, autometer pyro boost and trans on the a-pillar, muffler and silencer ring MIA. |
#10 (permalink) | |
#11 (permalink) |
From What little I know about how both system work the only difference is pretty much the Jet size and that you will not go as far on a tank of NG than Propane. Since Propane is stored as a Liquid and not as Gas. THis may be something that I will add to the 96 12v
#12 (permalink) |
Could ya use the same regulator and such that a propane kit uses? Or dose the whole system need to be redone. Is CNG at a higher pressure than propane. There is a shop in St. George, UT that wants like around $5500.00 to buy and install the kit. I'm not sure of the name of the shop, a friend called and asked me about it.
