Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 07-10-2008, 08:52 PM   #1 (permalink)
Transfer Pump
What kind of transfer pump is being used to obtain your WVO. My old one is worn out got it from Northern Tool 3/4 in and out not enough volume. what is your recomendation. 12v or 110v either will work i have a 1200 watt inverter. i dont want to spend more than $200 if i have to.
BeeGee is offline   Reply With Quote
Old 07-11-2008, 07:36 PM   #2 (permalink)
Transfer Pump
OK Lets forget the $200 how about a pumpfrom somebody anybody
HELLO IS THIS THING ON
Old 07-12-2008, 12:12 AM   #3 (permalink)
I use one of these
Model 26 Gasboy Electric Pump W/ Meter HIGH SPEED - eBay (item 280244631715 end time Aug-08-08 13:03:41 PDT)
Picked one up used, local off ebay for under $300. Sold the meter. Fills up a 275 gallon plastic tote in under 30 min. 4 valves, one 30 ft hose to suck or discharge oil.
Used one of these before that, it's alot slower.
Fill Rite FR1210C 12 Volt DC-15 GPM Transfer Fuel Pump - eBay (item 280242576012 end time Jul-13-08 16:30:00 PDT)
rock mafia is offline   Reply With Quote
Old 07-12-2008, 08:18 AM   #4 (permalink)
TEX
TEX's Avatar
I have 2 one is a small DC powered diesel transfer pump, got it from northern or harbor freight 3/4" in/out not super fast but works fine & cost $100. the other is a 18 GPM AC diesel pump 1" in/out cost $200. both are Tuthill i think is the brand
be sure and check the AMPS for you inverter. my small 3/4" pump draws 20 amps while the big one is way less.
2006 Quad Cab-Short bed-4X4-CTD-SLT-Silver-Auto-3.73-Big Horn Pkg-AeroTurbine 4040XL-MBRP 5" Dual Wall Angle Cut Tip see garage for pics-Blue Cool Hose Kit-Amsoil 4510-ISSPRO Turbo Timer/Monitor-285 BFG AT'S-BMK 11 By Pass-Draw Tite Gooseneck Hitch-DiPricol Optix Gauges Boost,EGT,Trans Temp
Wife:2005 VW Passat TDI
Work: 2004 Pierce Contender with 8.3L Cummins---Fire Truck
TEX is online now   Reply With Quote
Old 07-12-2008, 08:43 AM   #5 (permalink)
I use a small bilge pump from any boat supply store. It has a screen to keep the chunks out- uses 12v - so I have a little 12 volt battery that I bring around. You just lower the pump to the level in the oil and attach the wires to a battery. You only have 1 hose since the pump is submerged- and a pice of garden hose fits on just fine. Fills a 5 gallon drum in about 30 seconds. There heavy duty little pumps- and the fluid doesn't matter becasue they are designed to lay in the bottom of a boat and pump out all kinds of nasty fluids.
2001 extended cab, full bed 2500 4x4 superchiped, 160,000 miles , Running home brewed bio for 7 months- Hauling butt, smelling like french fries- Navy Cummins tech for 15 years
arcoen is offline   Reply With Quote
Old 07-14-2008, 06:41 AM   #6 (permalink)
speed185187's Avatar
12V pump
i use one of these to transfer WMO or WVO. Works great.
Tuthill Gear Pump — 12 Volt, 3.5 GPM, Model# FR1602NT | DC Powered Pumps | Northern Tool + Equipment
00 2500 2wd ext cab, SB. (BHAF, silencer ring MIA, Boost, EGT, FP Gauges, Breather bottle relocate, Fass 150/150, Fireball 150's, VA smart box, 4" exhaust)
03 Jetta TDI 5 spd "See tdiclub.com for all mods"
speed185187 is offline   Reply With Quote
Old 07-14-2008, 08:55 PM   #7 (permalink)
totalloser's Avatar
I use a 1" pump from www.homier.com They cost about $120 (beat THAT!) but are a slipper type. I don't know if that will work. You might need a gear type. I suck out tanks regularly with mine, just switch the polarity. The hose kinda sucks, and you might need to tighten fasteners. Cheap chinese junk.
01 24v 100hp tips, 4"ss BDbrake PSCpump 1.5"dom steering tapped box 1.5"ram manual CAD switch dual carters 3.55's LSD, big shaft nv5600/241HD 6 35's inners pulled in (no spacer) Ugly black and thrashed!
totalloser is online now   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
