| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#37 (permalink) |
MS Chapter VP
yup, set it at whatever you want, you could run the system at idle if you like.
04 QC/LWB 48RE 4x4: EJA, Arson CP3, BHAF, 4" TB stainless steel exhaust, 7" stack, Propane injection, Swanker intake manifold, GDP heater grid delete, BD 100 gal/hr pump, Big line kit, spin on fuel filter, Racor seperator, FS2500, mystery switch, 5 gallon on-board air system, Viair comp, Optima blue tops, 1875 Watt dvd stereo system, train horns. 6" lift w/35x12.50/20's |
#38 (permalink) |
hey bkjeffrey... when you run your do you see an improvement in fuel milage... or what did you get to increase..??
2003 2500 SWB 2wd, Leveled, Smarty Revo, Cool Tube, Silencer Ring & Heater Grid MIA, Train Horns(thanks to the gf), dual 6" mitors w/magnaflow,Cobra 29 w/K40, Blue LED Dash and Floor Lights, Recon Big Rig Lights, Prodigy, H2s.
#39 (permalink) |
Good luck. I built my own on my 93. Loved it. Here are a couple links that helped me with my build. Diesel Injection TheDieselStop.Com - www.thedieselstop.com I went with a perm. mounted propane tank off an old farm truck. You have to pay road tax on it but worth it. Nice power felt, improved mileage lower egt. Dang I should have kept my tank when I traded pickups!!!
2000 Quad Cab 2500, 4X4, 24V, Auto, BHAF, Banks Get-Kit with Ottomind, Banks Monster Exhaust, Glowshift Gauges, Refer Unit Aux. Fuel tank, Firestone Air Ride, Navigon GPS, Wallyworld 2-cycle.
#40 (permalink) |
MS Chapter VP
id say maybe 1 mpg in town, 3-4 on the highway. I feel a noticeable increase in power instantly though
#41 (permalink) |
Location: Shepherd, Texas, USA!!!! (North of Houston a bit)
OK. Got my kit installed today!! Went in great, very easy to install. I have 2psi out of the regulator and the Hobbs switch set to 2psi. Before the kit the MPG meter was pretty close to correct, due to the bigger tires without correction, based on hand calculation. When I would reset the meter with the cruise control set on 65 it would read 16-16.5mpg. Today when I reset it at 65, it read 28.5!!!!!!! If this holds true thats a 12mpg gain!!!!!! I know that this is a bit premature but I am optimistic.
2004.5 2500 4x4. Torque Tube gutted and Silencer Ring removed. Grid Heater gutted. Custom made 3" Intake Horn. Straight pipe'd. Edge Juice w/Attitude. 4" Superlift. H2 wheels w/ 315/70/17 BFGs. Smoke Switch. PROPANE!!!! |
#42 (permalink) | |
BOMBS AWAY!
01.5 Flame Red 3500 DRW 2WD LB QC Laramie 09 SRT8 Challenger *On Order* 47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel. |
#43 (permalink) |
Well I have only put about 200 miles on the truck since install and the MPG meter has settled around 23.5 with a good bit of stop and go in town so Im pretty happy. The system works great so far.
#45 (permalink) |
Overhead. But since I have not reprogrammed the computer to correct for the 35s the overhead has been pretty close to correct base on previous hand calculations.
#47 (permalink) |
I already had a number of the parts is the reason mine is so cheap. Heres my parts list. 20Lb BBQ tank - Had Acetylene Regulator - Had 20' or 1/4" Air hose - $5.40 1/4" Solenoid Valve - $28.00 Shipped 2psi Hobbs Switch - - $26.00 Shipped Various fittings and clamps - ~$15.00 Here is a quick diagram I drew up in paint. Hobbs switch is a pressure switch screwed into the intake manifold to see boost.
