| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#253 (permalink) |
The inlet size will affect the volume of propane being injected into the system, since volume is a function not only of pressure, but of orifice size. Obviously patracy's played with his pressures enough to figure it out... I'm going to buy a dry nitrous (stainless) orifice for mine, just so I don't have to fab something.
'94 3500 DRW 4x4; auto; 4.10 gearing; 10' flat bed; BHAF/heatshield; FBD budget 5" TBE w/ cat delete |
#254 (permalink) |
update: my 1st propane tank didn't work out too well, i was not able to get consistence output through my propane regulator. I used up the whole bbq tank in less than 500 miles and the total mpg was 24mpg not counting the propane usage. So in reality im not gaining anything. Previous test was done with too many variable, so this time im trying to keep the propane setting as low as posible but the regulator is too touchy and the guage is too sensitive to a point that it keeps on change. I might have to buy a constant 1.5 psi output vaporizer, but that is upward in the $200. Can anyone tell me where i can buy a vaporizer for less 'cause after all, this is just a diy project. The less money spent on the project the better the rewards you get.
#255 (permalink) |
GA Chapter Vice President
I'm running a $20 adjustable regulator I got from Tractor supply. I'm using a pressure gauge before the solenoid valve to know what my pressure is.
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse BHAF, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan. Parts to come: 150hp sticks, turbo, and bigger exhaust. |
#256 (permalink) |
good read!!!!!! may have to try this this month. even if fuel is 3.14 now
1983 F-350 Crew cab 4x4 4.10 5 speed 90 cummins 12v, turned up pump, centerforce clutch, stright piped stack on its way.,97 alcoa ford wheels, with custom built flatbed 265 85 16s |
