Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 09-11-2008, 11:09 PM   #229 (permalink)
Thissideup's Avatar
This has got me thinking, one of trying it on my dodge and two of trying it on my western star, now you say that you can't inject propane unless you have boost, but what about rigs with exhaust brakes? Both my dodge and my Star have an exhause brake and while I have no guage on the dodge I know the Star regularly sees 5-8 psi boost while jaking, which if I read correctly would trigger it to inject propane. Now I've been thinking about this and have come up with a couple of possible solutions, one is to put a two way switch between the jake and the propane setup, so that only one can receive power at a time, or to install a relay powered by the jake wire to open the circuit when it is hot. Now that said, do you think the propane will actually have a negative affect while exhaust braking or am I over thinking this?
Thissideup is offline   Reply With Quote
Old 09-13-2008, 05:43 PM   #230 (permalink)
Thissideup's Avatar
I take it this dog has been put to sleep
Old 09-13-2008, 06:26 PM   #231 (permalink)
GA Chapter Vice President
patracy's Avatar
Nope, still have mine, no problems, great mileage and power. Just haven't a clue about the brake thing.
I thought a brake was a butterfly that closed on the exhaust side causing backpressure? How would it cause boost?
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse BHAF, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan.
Parts to come: 150hp sticks, turbo, and bigger exhaust.
patracy is offline   Reply With Quote
Old 09-13-2008, 06:30 PM   #232 (permalink)
Lower Slower Delaware
cowbully's Avatar
Originally Posted by Crazytexan View Post
Just bite the bullet like I did and drive around a 1991 HONDA CIVIC 4 DR WITH A 1.1LITER 4 BANGER, 5SPD, BABY BLUE AND RUST, with mold in the AC........but it gets 40mpg baby! I take the truck out at night and on the weekends.
Yeah I just bit the bullet myself. Last monday I bought a 1984 VW Diesel Rabbit. No options, no shine. Baby Blue as well with 53K original miles for only $1800. OH YEAH IT GETS 50 MPG's
'96' 3500 4x4 12 valve Aurora 5K Turbo DragonFly P-Pump KDP Tabbed FASS BHAF Banks Twin Ram 6" Bull Haulers and a few aces in the hole NO FARMS NO FOOD
I.U.O.E. Local 542 "America is formed by heavy equipment"
cowbully is offline   Reply With Quote
Old 09-13-2008, 06:38 PM   #233 (permalink)
patracy's Avatar
All of my bikes (I ride bikes as my main mean of transport) get 45+ mpg.
Making progress on the samurai, that'll get me about 30mpg on diesel. (WVO) I'm getting tired of riding so I need something to drive on four for a while. (I ride about 30K a year on a bike)
Edit: There's nothing wrong with trying to get better mileage out of a "toy" either. :
Old 09-13-2008, 10:45 PM   #234 (permalink)
Thissideup's Avatar
Like I said I'm not sure if the dodge does, I know the star will make boost while jaking, but the mechanics are not the same, I believe but am not sure that jacobs brakes cause a delay in the exhaust valves opening, perhaps holding back pressure on the intake side, aswell my star doesn't have a waste gate, so that might contribute, I will have to put a boost guage on the dodge and experiment. I'm going to follow your wvo thread aswell, I have access to 2000 litres of new canola oil that was supposed to be used to lubricate instrumentation in the local oil patch, the company that bought it was going to dispose of it, so our driver claimed it and now it's mine.
Old 09-13-2008, 10:48 PM   #235 (permalink)
patracy's Avatar
Might wanna look into biodiesel. It looks like you've got a 2nd gen. If you've got a VP44/24V, they don't take to well to a WVO setup. If you've got an older 12V P pump, you're in luck!
Old 09-13-2008, 11:28 PM   #236 (permalink)
Thissideup's Avatar
Actually was thinking propane for the dodge and wvo for the tank truck, it's a 3406 B mechanical caterpillar, I'm told that they fare well with wvo,
Old 09-14-2008, 09:58 AM   #237 (permalink)
mailman1175's Avatar
WVO = Waste Vegetable Oil, as in not new
I don't know if that makes a difference or not to your VP44, but you don't have WVO.
Carry on.
'94 3500 DRW 4x4; auto; 4.10 gearing; 10' flat bed; BHAF/heatshield; FBD budget 5" TBE w/ cat delete
mailman1175 is offline   Reply With Quote
Old 09-14-2008, 04:48 PM   #238 (permalink)
patracy's Avatar
Makes no difference. Viscosity is the issue.
Today I might have found a happy median though. 50/50 JetA and WVO with the ball valves for heat 1/2 way open.
Old 09-22-2008, 10:54 PM   #239 (permalink)
just did install home built kit from ebay parts and ace hardware. Just filled up full take diesel and 5 gal propane from Walmart. Normally get 18mpg cruising at 66-69 and about 10% city driving. I'll post some result next fill up. in about a week.
hait is offline   Reply With Quote
Old 09-23-2008, 12:11 PM   #240 (permalink)
35 miles one way to work all highway this morning. The LOM(lieometer) reads 26mpg@69mph, 28mpg@65mph, 30mpg@64mph, and 32mpg@62, and all reading are done when driving flat and no change in load/boost while pressing the "rest" button on the LOM to read the giving instant ave mpg. My spec: 05 qc auto 3.73 w/35", stock intake with k&n filter, cat and muffler cut off and replace with straight muffler from local muffler shop. I have an Edge used as gauges only, and Smarty set on #4. Im averaging 18mpg before the propane, if i run the tank dry i would get 18x34gal.=612 miles. With propane almost same as diesel per gallon, and a 5 gal. lp is added to the equation i would have 39gallons and the truck have to yield 18x39=702miles dry to make it even, anything yielding more than 702 miles is positive gain in milage.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
