| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#13 (permalink) | |
Location: Shepherd, Texas, USA!!!! (North of Houston a bit)
2004.5 2500 4x4. Torque Tube gutted and Silencer Ring removed. Grid Heater gutted. Custom made 3" Intake Horn. Straight pipe'd. Edge Juice w/Attitude. 4" Superlift. H2 wheels w/ 315/70/17 BFGs. Smoke Switch. PROPANE!!!! |
#14 (permalink) |
GA Chapter Vice President
Ok just bought the ebay stuff you listed. Looking for a regulator now. I'm going to get them to set the hobbs switch to 4psi. What are you doing on fuel lines? I can setup hardlines for the tank-reg-solenoid. Would some of this spare 1/2" fuel hose be ok? (good to 35 or 40psi if I remember correctly, but I should only see ~4psi tops feeding through this section) Also what about the nozzle? I've got a BHAF so I'm going to have to install the tap into the tube between the filter and turbo. Here's a pic of a nozzle someone else built I was thinking about...
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse BHAF, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan. Parts to come: 150hp sticks, turbo, and bigger exhaust. |
#15 (permalink) |
One thing I was just reading was that propane along with a timing box is a no-no. The propane itself advances the timing, then if you have a timing box you could have too much timing and that could be disastrous (so I've read)
2001.5 2WD, Auto, MBRP 4" |
#16 (permalink) | |
#17 (permalink) | |
#18 (permalink) | |
2004.5 2500 4x4. Torque Tube gutted and Silencer Ring removed. Grid Heater gutted. Custom made 3" Intake Horn. Straight pipe'd. Edge Juice w/Attitude. 4" Superlift. H2 wheels w/ 315/70/17 BFGs. Smoke Switch. PROPANE!!!! Last edited by McLarenross : 05-28-2008 at 11:21 AM. |
#19 (permalink) |
Please explain to me what happens in the case of an accident where you are knocked out or for what ever reason you can not turn off the ignsw ? Bob
05 2500 4x4 Advanced dominator 3.0 suspension+long travel airbags by Carli Baja proven |
#20 (permalink) | |
#21 (permalink) |
im signing up to follow this one... id like to see how it turns out and wht kind of results you realize. also, post up what tank you decide to use... if its going to be a normal BBQ tank or some kinda slim line camper tank under the bed or whatever.
`97 12v 2500, STD cab, 12v, #100 plate, tweaked AFC, Tabbed KDP, 4" FBD exh, BHAF, Built 47RE/VB/DTT 89% TC, 2wd, 3rd Gen Rims, 3.55's, PSI/Trans/EGT guages... And a `97 Dually "Handshaker"! |
#22 (permalink) |
Normal BBQ tank. Just going to hide it in the toolbox.
#23 (permalink) |
Yea. If done this way the system is automatic and wont work unless you are seeing the amount of boost you set the switch to activate at. Mine is at 2psi. Im just using a BBQ tank for now but i will go ahead and get a under truck mounted propane tank later once I have completed the testing.
#24 (permalink) |
For a science project in high school, I ran my truck on a smog dyno with a propane tank putting propane directly into the air intake. Since propane is a relatively low-pressure gas, I don't see why people use nozzles and try to adjust flow rate with nozzle size. I just used a 0-5 LPM flow meter on my jury rig. It felt like it added a lot of power on my truck, but that was back when it was stock. And 5 liters per minute was really, really putting out a lot of unburned hydrocarbons. Made your eyes sting like a nitro car with a dead cylinder...
1990 D-250 Regular Cab: Full power screw; stout TC and A518 w/ manual valve body; ratchet shifter; piston LP; Ramcharger tank; manual off; computer-programmable 40 GPH water/meth fumigation; gauges |
