Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 07-11-2008, 04:36 AM   #193 (permalink)
GA Chapter Vice President
patracy's Avatar
Originally Posted by tigerfalcon50 View Post
RIIIIIIIGGGGGHHHTTTT....ANNYYWWAAAYYSSS!!!!
I just figure the hole in that female to female npt is large and with 1.5 psi running through it and the area that is inside that part, it's pushing more propane at 1.5psi then something with a smaller hole. The volume of propane being put into the intake is what i'm concerned about. The 1.5psi does matter if you run it through a syringe or a milk jug...the volume will be different. So if you use a larger opening, would you need to run less propane? I like the part because it's simple but the volume concerns me.
He's said his peace, he's entiled to that at least. I admit he even does have valid points. So I make no promise/warrentee/or libility over what anyone does with thier truck.
As to the question about pressure vs. volume. That's why you run low and build up. Since my setup is contained in the toolbox, I don't know the pressure during the apply. I'll have to get my wife to drive me down the road and I'll make note of it.
I've still not refilled the propane on the truck yet. I just got my draw straw installed, so I've been needing to suck the diesel down. Now I've got to replace the fuel pump I damaged.
I do wish to upgrade my propane hose. I'm thinking that'll be next. And I'd like to keep the current setup, but somehow find a vacuum regulator for the front of the setup to prevent loading. Course I could just pick up another 1/4" solenoid and wire it in at the front.
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse BHAF, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan.
Parts to come: 150hp sticks, turbo, and bigger exhaust.
patracy is offline   Reply With Quote
Old 07-12-2008, 03:41 PM   #194 (permalink)
how are ya'll putting the hobbs switch on the factory intake horn??
2004.5 Ram 2500 5.9L 4x4 3.73s Edge EZ, Willy's Whistler air intake, muffler MIA, lube and filter by AMSOIL, Extang Tono Cover "do yourself a favor, always get your dog or cat spade or neutered and always hand calculate your mileage"
tigerfalcon50 is offline   Reply With Quote
Old 07-12-2008, 04:15 PM   #195 (permalink)
dieselfurry's Avatar
pipe tap........
01 5sp adrenaline, air dog 150,valair clutch for 600hp, BHAF, 150's FBD injectors,super b special, propane......
dieselfurry is offline   Reply With Quote
Old 07-12-2008, 05:29 PM   #196 (permalink)
patracy's Avatar
Well you could use a NPT tap and drill and tap the intake. But I found it easiser to just use the factory intake port. It's located between the MAP sensor and fuel filter (on second gen, likely the same on laters).
Just use a set of reducing bushings from 3/4" to 1/2" to 1/8". I used a 2" nipple to a 1/8" tee then threaded the hobbs switch in one port, and ran my hose for my boost gauge from the other.
Image stolen from mopar1973man guage install. This shows the location.
Old 07-14-2008, 12:15 PM   #197 (permalink)
anyone know where this factory intake port would be on a 3rd gen?
Old 07-15-2008, 07:25 AM   #198 (permalink)
McLarenross's Avatar
Location: Shepherd, Texas, USA!!!! (North of Houston a bit)
I dont think we have one. I taped the intake manifold.
2004.5 2500 4x4. Torque Tube gutted and Silencer Ring removed. Grid Heater gutted. Custom made 3" Intake Horn. Straight pipe'd. Edge Juice w/Attitude. 4" Superlift. H2 wheels w/ 315/70/17 BFGs. Smoke Switch. PROPANE!!!!
McLarenross is offline   Reply With Quote
Old 07-15-2008, 01:40 PM   #199 (permalink)
So I figure just take it off, drill it, but what are you using to seal it up with??
Old 07-15-2008, 06:20 PM   #200 (permalink)
Teflon tape.
Old 07-17-2008, 02:25 PM   #201 (permalink)
Why no more updates?
44mag is offline   Reply With Quote
Old 07-17-2008, 02:48 PM   #202 (permalink)
MS Chapter VP
bkjeffrey's Avatar
Heres what mine looks like....
I used a negative pressure regulator, and a Hobbs switch set @ 5 lbs. Works perfect, stop and go or on the highway. One my boost gauge hits 5 lbs I get a pretty good instantly noticeable increase in power. I actually on my second tank of propane and have had no problems since. I wired the system on an LED toggle, And wired the toggle to the ignition so the toggle is disabled unless the engin is running.
My tank.
My regulator
My Hobbs switch.
Diagram of the whole thing.
04 QC/LWB 48RE 4x4: EJA, Arson CP3, BHAF, 4" TB stainless steel exhaust, 7" stack, Propane injection, Swanker intake manifold, GDP heater grid delete, BD 100 gal/hr pump, Big line kit, spin on fuel filter, Racor seperator, FS2500, mystery switch, 5 gallon on-board air system, Viair comp, Optima blue tops, 1875 Watt dvd stereo system, train horns. 6" lift w/35x12.50/20's
bkjeffrey is offline   Reply With Quote
Old 07-17-2008, 03:43 PM   #203 (permalink)
What kind of mpg's berore and after? How are you metering the flow into the intake side?
Old 07-17-2008, 06:52 PM   #204 (permalink)
patracy's Avatar
Me personally...
17.5mpg on diesel
29mpg on diesel with propane
Regulator on mine is back at the tank. His is the round regulator in the second pic. That's what regulating the flow/pressure.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
