Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 07-01-2008, 12:20 AM   #145 (permalink)
alright, moving across the country and really not happy with power or mileage so i think i'm going to pull the trigger on this set up. Is there any preferred (read: cheapest and most effective) tubing to run from the regulator up to the block?? Keep up the good thread.
2004.5 Ram 2500 5.9L 4x4 3.73s Edge EZ, Willy's Whistler air intake, muffler MIA, lube and filter by AMSOIL, Extang Tono Cover "do yourself a favor, always get your dog or cat spade or neutered and always hand calculate your mileage"
tigerfalcon50 is offline   Reply With Quote
Old 07-02-2008, 09:34 AM   #146 (permalink)
BOMBS AWAY!
hipsi's Avatar
Propane has no corrosive properties when in contact with steel or rubber hose.. Aluminum is another story however.
I paid $0.21/FT for ¼” synflex airline (Used as airlines on OTR trucks/trailers)
I went with synflex over rubber fuel line because synflex has much higher tolerances to temperature changes and performs well cold (when filled with propane perhaps).
01.5 Flame Red 3500 DRW 2WD LB QC Laramie
09 SRT8 Challenger *On Order*
47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel.
hipsi is offline   Reply With Quote
Old 07-02-2008, 01:45 PM   #147 (permalink)
run nitrous. imo its safer and easier on the engine. most people that i speak with would agree.. but i've been wrong before
2007.5 6.7L S&B INTAKE PPE PROGRAMMER EDGE INSIGHT RECON SMOKED CAB LITES 4" MBRP DPF BACK EXHAUST AMSOIL BMK-11 BYPASS OIL FILTER TINTED BLACK SPRAYED BEDLINER TRUXEDO COVER GENOS GRILLE GUARD & STAINLESS INTERCOOLER CAP 33" BFG ALL TERRAINS
TORK-STIK is offline   Reply With Quote
Old 07-02-2008, 01:49 PM   #148 (permalink)
GA Chapter Vice President
patracy's Avatar
You've not been paying attention to this thread. We're not doing it for power. We're doing it for mileage.
27mpg on diesel and propane here.
PS, nitrous doesn't have the same effect on a diesel. It's used more or less to lower EGT's.
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse BHAF, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan.
Parts to come: 150hp sticks, turbo, and bigger exhaust.
patracy is offline   Reply With Quote
Old 07-02-2008, 02:04 PM   #149 (permalink)
dieselfurry's Avatar
where exaclty did you put you nozzel? i have a -pressure regulator and i cant seem to get enough vacuum to get it to release....
01 5sp adrenaline, air dog 150,valair clutch for 600hp, BHAF, 150's FBD injectors,super b special, propane......
dieselfurry is offline   Reply With Quote
Old 07-02-2008, 02:13 PM   #150 (permalink)
BOMBS AWAY!
hipsi's Avatar
The propane is being injected into the turbo.
Old 07-02-2008, 02:21 PM   #151 (permalink)
i understand that before the turbo but where? is it okay to put it within a 1 or 2 inch in front because i cant get enough vacuum inside the air filter to get it to release. I have a negative pressure regulator.
Old 07-02-2008, 02:45 PM   #152 (permalink)
patracy's Avatar
Ahhh ok. I'd say that'd be fine. But you likely going to need a venturi nozzle for your setup. This will allow a vacuum for your regulator.
Old 07-02-2008, 02:47 PM   #153 (permalink)
this is the kit i have.....
eBay Motors: DIESEL PROPANE INJECTION KIT-GAIN UP TO 100 HP! NEW! (item 180260638686 end time Jul-05-08 10:24:56 PDT)
Old 07-02-2008, 03:20 PM   #154 (permalink)
McLarenross's Avatar
Location: Shepherd, Texas, USA!!!! (North of Houston a bit)
Guys. Its yall lines that is the reason your using so much propane. I tried air hose and fuel hose both and vaporized propane will leak right through the line. Im working on getting purpose built Propane line with fittings made now. Will let yall know how that goes.
2004.5 2500 4x4. Torque Tube gutted and Silencer Ring removed. Grid Heater gutted. Custom made 3" Intake Horn. Straight pipe'd. Edge Juice w/Attitude. 4" Superlift. H2 wheels w/ 315/70/17 BFGs. Smoke Switch. PROPANE!!!!
McLarenross is offline   Reply With Quote
Old 07-02-2008, 03:35 PM   #155 (permalink)
patracy's Avatar
I'm not using air hose. Never have. Nor fuel line. I'm certain my useage was from the liter or so that went out into the air from all the dozens of times I took it apart replacing. And the high pressure I ran before. Haven't been running it since I'm trying to drain my diesel tank for a draw straw install.
Old 07-02-2008, 03:42 PM   #156 (permalink)
will putting it right up next to the turbo work better for my situation?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
