| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#121 (permalink) | |
GA Chapter Vice President
You'll need the following... Propane tank Adjustable propane regulator (I got mine from tractor supply $20) or a cutting torch regulator. 1/4" solenoid (from ebay $30) Hobbs pressure switch ($20, also from ebay) a few 1/4" sections of pipe 1/4" tee Reducing plugs Hose 2 1/4" NPT to hose barb Hose A bung or something to thread the other nipple in. fender washer lock-tight hose clamps 16ga wire switch indicator light switch mount (if you don't want to put it in your dash) fuse link screws tie wraps electrical tape terminal connectors splice connectors
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse BHAF, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan. Parts to come: 150hp sticks, turbo, and bigger exhaust. |
#122 (permalink) |
BOMBS AWAY!
Are you running the solenoid as close to the injection point as possible or as closer to the bottle valve? It would make sense to me to have the shut off soleniod right at the injection point which will allow almost instant cut off of gas when you dump the throttle.
01.5 Flame Red 3500 DRW 2WD LB QC Laramie 09 SRT8 Challenger *On Order* 47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel. |
#123 (permalink) |
I've got mine right at the tank. But it'd be better to install it right at the injection point for instant on/off. Only problem is you'll get fluctuated pressures going into the engine since the hose can expand. You might get a harder "hit" than expected. I did get a bark at low speeds when I tried running my setup. So I only use it at highway speeds now. (Not in traffic)
#124 (permalink) |
BOMBS AWAY!
Makes sense.. did you ever think of another regulator before the injection point to stop pressure creep?
#125 (permalink) |
Not really. But thinking through it, the way to "fix" this would be to leave the reg at the tank. Then use hardline tubing (Alum is the cheapest) to the engine. Then install the solenoid. Tuning two regulators would probably be a pain.
#126 (permalink) | |
The downside that I see right off the top of my head is that, with a greater distance between regulators, the odds of you having a 10 psi leak are much greater than those of having a (for example) 3 psi leak. So the chances of emptying your tank before you know it are better. The upshot seems to be that you greatly decrease the effects of temperature fluctuations. Even with aluminum (or brass, I suppose) tubing, you're going to have temperature affecting pressure in the fuel line. The expansion of rubber lines with the vapor really isn't the issue; it's the increased volume that comes with the higher temps. That's why you probably do want your regulator as close to the injection point as possible. My old boss had 3 different gasoline-engined trucks that he converted either to run solely on propane or dual-fueled, propane and gasoline. In all cases, the regulators were very close to the point where the fuel was to enter the cylinder (two carbureted engines, one fuel-injected). The concepts of adding propane to diesel fueling and running a gas engine on propane alone are, of course, fundamentally different, but the "over-fueling due to pressure/volume/temperature fluctuations" would seem to have equally undesirable consequences in both types of engine. This is all just so much thought and theory to me at this point, though. That's where it'll have to stay until I can, A) be convinced of enough cents/mile savings to make the experiment worthwhile, and, B) get some money scratched together to attempt said experiment. So, if any of you guys who're actually doing this have experience which refutes my ramblings, please feel free...
'94 3500 DRW 4x4; auto; 4.10 gearing; 10' flat bed; BHAF/heatshield; FBD budget 5" TBE w/ cat delete |
#127 (permalink) |
Couple of pages back I posted up my results. 29mpg. Honestly I'm giggly about it. I've hated this truck until that. Simply put, if a tank of propane will last a tank of diesel. I'll spend $140 to go 1K miles. It would have cost $205 on diesel.
#129 (permalink) |
Is the teflon type tape that gas fitters use, yellow or white? Shouldn't this testing be on something disposable like a DURAMAX!
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods 1980 Mack Cruise-Liner Cummins N14 370/430 hp 10spd,air ride |
#130 (permalink) | |
#131 (permalink) | |
Why would you test this on a duramax? It wouldn't need it unlike the cummins.
#132 (permalink) | |
If I see the kind of mileage gains you've seen, though, no doubt: I'd be giggly, too.
